Ramps and Jack Stands? - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 08-20-2010, 09:41 AM Thread Starter
Hi All,
First thanks for all the incredible info I have gained from you all.
Well I am ready to do my first oil change on my 2010 truck F250 (a little over 4K miles on it) and I have a question. I have a set of ramps (6 inch high) and rated to 3K pounds each. Once I drive the front up of the truck on the ramps, I will place the truck in park, set the park break, and chock to rear wheels. Now I have read that is reccomended to also use jack stands with ramps. Here is where I am confused. As most jack stands have finite adjustment (usually in about one inch steps) when using a jack, I jack the car/truck to slightly higher than the desired height, adjust the jack stand to the next lowest adjustment, place the jack stand appropiately, then lower the car/truck onto the jack stand. Transferring most of the load from the jack to the stand.
So I must be missing something. How does this work with fixed ramps and a jack stand with finite adjustments? How do you transfer the load to the to the jack stands?....can't lowerer the ramps?
Seems like the jack stand will always be not in contact with the car/truck (set just lower than the ramps)...I am sure I am missing something that is very obvious.
Thanks in advance for your thoughts and input...
Last edited by 5thwheel-in; 08-20-2010 at 09:42 AM. Reason: correcting gross misspellings!
5thwheel-in is offline
post #2 of 10 (permalink) Old 08-21-2010, 04:16 AM
TDW
The jack stands are there as a safety factor and you raise them as close to the frame as you can. Your ramp rated for 3K lbs is not giving you as much margin as you may believe. I bought a set of "heavy duty 10K GVWR" ramps and the section that transitions from the ground to the platform part of the ramp buckled while trying to drive up the ramp. After bending them straight again, I now put wood blocks under the transition part of the ramp as well as the platform part of the ramp. The truck front end with the big diesel weighs a lot. I took my truck and trailer to the truck scales to see where I now am at. With my fifth wheel hitch mounted, full tank, and auxilliary tank full I came out at 5360 lbs on the front axles and 4160 lbs on the back for a combined 9520 lbs. So even though your ramps say they are rated for 3K each I would not trust them. The supports are usually held by a couple rivets and under that weight it can let go and it will bounce down hard and fast. Make sure your jack stands are rated for the load as well. Be careful.
TDW - Purchased July, 2008
2008 Black F350 Lariat
DRW 4x4 Crewcab Long Bed Job 3
6.4L PSD
Navigation System with Audiophile
Tow Command
3.73 Read End
13k LB Carriage Cameo 5th Wheel
TDW is offline
post #3 of 10 (permalink) Old 08-21-2010, 11:21 AM
floridarandy's Avatar
i bought 12,000 lb ramps at Northern Tool....not expensive but great piece of mind since they only deal with one end of the truck at a time.
2008 F250 King Ranch Black 4x2. Stock. Purchased July 2010 with 28,000.
floridarandy is offline
post #4 of 10 (permalink) Old 08-21-2010, 11:36 AM Thread Starter
So are your "12000 lb ramps" rated at 12000 pounds capacity each or are they rated for a 12000 pound GVW? My ramps are rated for a 12000 GVW which yields individual ramp capacities of 3000 lbs.
Here is a link to the ones I have:
They are Blitz Rhino Extremes rated for a 12000 GVW vehicle. They are very substantial. I like them lots...
post #5 of 10 (permalink) Old 08-21-2010, 11:39 AM
stoverbro's Avatar
Is your truck a 4x4 or 4x2? I have a 4x4 and have never had to raise it to change the oil. Even on a creeper i fit, and im not skinny lol.
2010 Lincoln MKS Ecoboost Ultimate 107,000 miles
2008 F-450 6.4 Crew Cab 4x4 Lariat 210,000 miles
2003 F-250 6.0 Crew Cab 4x4 Lariat 330,000+ miles
2002 Jeep Grand Cherokee Limited 175,000+ miles
2001 60th Anniversary Grand Cherokee 195,000(Rock crawler)
stoverbro is offline
post #6 of 10 (permalink) Old 08-21-2010, 11:59 AM
I myself have a 2WD and have never had to raise it to change the oil either. I used to just crawl underneath, but found it was easier to do with a creeper.
Go get a creeper. :-)
2008
F250 PSD XLT Super Cab Long Bed (4x2)
2006 Nissan Titan, 6 inch Procomp lift (4x2)
2000 Nissan Frontier, Custom Motorsports 8 inch lift (4x2)
timid1 is offline
post #7 of 10 (permalink) Old 08-22-2010, 08:46 AM
senix's Avatar
I would buy at least 6K ramps. Mine are rated for 6K each so 12K total capacity.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #8 of 10 (permalink) Old 08-22-2010, 11:07 AM
Yep, I fit under mine no problem.
ChargersFaninCO is offline
post #9 of 10 (permalink) Old 08-22-2010, 11:32 AM
fddriver2's Avatar
Me too. I'm well over 200 lbs and the truck is 2 wd. Ditch the ramp and jack stands. Chock the wheels and slide under.....
I have a philosophy? Who knew. Ok, where's the beer?
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\Edge Evolution2\Zoodad\2008 Diff cover\V-10 Transmission cooler
fddriver2 is offline
post #10 of 10 (permalink) Old 08-22-2010, 11:46 AM
wingnut60's Avatar
And get a Fumoto valve for the drain...........
Joe
2017 F450 KR
2010 F450 Lariat 4x4--died, but reborn, traded
2009 F450 Lariat 4x4--died, scrapped
2007 F350 KR DRW CC 4x4-Gone to pasture
2015 Mobile Suites 38RSSA--hoping for another 10 years
2005 Mobile Suites 36TK3--traded, 10 years of camping memories
wingnut60 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
