Spooling/Reving noise from under hood - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 08-07-2019, 01:35 PM Thread Starter
This has plagued me for many years and I have finally had it.... Mostly during hot weather (90 degree+) and at speeds under 50 mph I can occasionally will hear something spooling or reving up like a jet engine (thats the best way to describe it). When the noise occurs I see no increase in RPM or boost and it throws no codes. I have had it over to my local dealership and they were worthless.... They can troubleshoot without a code. What ever happen to real mechanics!!!! Sorry back on subject..... What else could cause the noise that sound like a jet engine under my hood. My co-work is thinking it may be the fan, which is possible but I'm not sure how to test. And if it's not the fan what else could it be???? I did just pickup a OBD2 data logger and hope to connect it this weekend to see if it will provide me ant insite. Thanks in advance for any suggestion you may have.
Sorry the truck is a 2009 with the 6.4
dnaber is offline
post #2 of 7 (permalink) Old 08-07-2019, 04:01 PM
MY 7.3 sounds just like you describe when the fan kicks in. So my guess is that is what it is.
DENNY
DENNY is offline
post #3 of 7 (permalink) Old 08-09-2019, 10:23 AM
TD-5's Avatar
Its the cooling fan increasing in speed. you may also hear the same sound for a short period when you start away first thing in the morning as the PCM performs a self test on the fan
2010 F350 KR CCLB, mini max & more
TD-5 is offline
post #4 of 7 (permalink) Old 08-10-2019, 07:11 AM
ford_doctor's Avatar
Boy that would be way too easy to explain. Whatever happened to real truck owners!!!
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #5 of 7 (permalink) Old 08-10-2019, 11:52 AM Thread Starter
So, if its the fan clutch making the noise, have you guys replaced the clutch to resolve the noise?
dnaber is offline
post #6 of 7 (permalink) Old 08-10-2019, 07:58 PM
It is not the clutch just normal fan noise. Go to a small airport most of the noise you hear when a plane takes off is that big fan up front not the engine.
DENNY
DENNY is offline
post #7 of 7 (permalink) Old 08-12-2019, 06:10 PM
The fan clutch is electrically controlled. When the air conditioner, trans, or engine needs it then engine control module controls it for higher speed. Fan noise is good. It means you or the powertrain is getting cooled down better because of that noise. Listen when trucks take off at an intersection. You will often hear the truck go off with low noise and then all of sudden it jet engine noise time. Med and heavy duty trucks often use air controlled fan clutch and they get big time noisey when they kick in and some times it even kicks up a short dust storm
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is online now
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
