Tow Haul problem - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 03-03-2012, 09:39 AM Thread Starter
Question Tow Haul problem
Hi: I have a tow haul problem with my 2008 F350 6.4L. It will not go into tow haul unless I tilt steering wheel up all the way and than slam it down and than it will engage. Than when I want to take it out, I have to shut off truck. Does any one have a wiring diagram and info on how to get at the wiring. Do I have to disarm Air Bag and pull Steering wheel? It has been like this for a year or more and no warranty on that part they tell me. Any help should help, [email protected]
Thanks Haakeye
haakeye is offline
post #2 of 8 (permalink) Old 03-03-2012, 02:51 PM
Mark Kovalsky's Avatar
My Photos: (6)
You don't have to disarm the airbag or remove the wheel. The screws that hold the plastic steering column are located on the underside of the column. Remove the cover and you'll see the damaged wires where they enter the shift handle.
Either repair the wires or replace the shift handle. They are around $65 at a dealer.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is online now
post #3 of 8 (permalink) Old 03-05-2012, 09:22 PM
Thanks Mark
I will try that if it works I will let you know.
Nick Name Haakeye 2008 F350 SD CC dually 4X4 LB Black, also 1970 F100 sb 13.0 in 1/4 mile in 1972
haakeye50 is offline
post #4 of 8 (permalink) Old 03-05-2012, 10:10 PM
guardrail22's Avatar
wiring diagrams can be obtained from Helm,inc on their website
subscription is about $20 per month
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2013
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline
post #5 of 8 (permalink) Old 03-11-2012, 09:53 AM Thread Starter
Smile Thanks
Thanks Mark I tried to figure out wiring and switch and than bought a new lever and switch. works well now. I than took the old one apart even further and found the broken wire, I repaired that wire and now I have a spare unit.
Thanks again.
haakeye is offline
post #6 of 8 (permalink) Old 04-08-2013, 10:05 PM
Tow/Haul Problem
Hey Guys, I have the exact same problem. I'm trying to be fairly careful with removing the plastic covers. I don't want to damage them, but they seem to be really difficult to pull apart. Any suggestions???
Mark
(08' F-350 6.4L Auto)
kmeeker is offline
post #7 of 8 (permalink) Old 04-10-2019, 07:04 AM
tow haul problem
hello I have a 08 f250 ,it has gotten to the point where it will only go into tow haul if im in park .it used to engage while in drive and then only in neutral and now just park ,would this be the same wiring problem ,thanks
riman625 is offline
post #8 of 8 (permalink) Old 04-10-2019, 07:50 PM
My Photos: (6)
Yes, it would be the same.
Mark
Former
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
