'2008 SCT X4 Tuner - Smoke? - Diesel Forum - TheDieselStop.com
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
post #1 of 6 (permalink) Old 04-14-2018, 09:09 PM Thread Starter
Brad777's Avatar
My Photos: (22)
Question.., the exhaust fumes are pretty strong and the truck smokes a bit when taking off from a stop or under pretty good acceleration. I'm surprised that it smokes as much as it does given it supposed to be running a stock tune (per the installer) via SCT X4. FYI, EGR has not been deleted. How much smoke is normal? Should I be concerned about the exhaust fumes? I have no experience with these so I'm looking for thoughts from those who do.
The truck is used primarily for towing, therefore it is low mileage...about 64k. The MPGs and performance from stock is remarkable!
2008 Ford F350 Long Bed
White/Pueblo Gold Accent
Lariet, Automatic
Loaded, w/exc. to Navigation
Skyjacker 6" Lift and Steering Stabilizer
Toyo 37"x13.5-20 MTs
Chrome Centerline Grizzly Rims
4.56 Gears
Amp Research Electric Steps
Firestone Ride Rites
Brad777 is offline
post #2 of 6 (permalink) Old 04-15-2018, 11:03 AM
79jasper's Avatar
Check your air filter.
But I doubt it's running a stock tune. If you have the sct, check it yourself.
Sent from my SM-G892A using Tapatalk
79jasper is offline
post #3 of 6 (permalink) Old 04-15-2018, 11:31 PM Thread Starter
Brad777's Avatar
My Photos: (22)
I'm thinking the same as you Jasper. I can't imagine the power it has and the smoke on a stock tune. FYI, I avoided checking the SCT due to laziness on my part. I didn't install it so I figured I could leave it alone and hide from the required learning. However, I'll take your advice and do so.
BTW, my truck is due for annual maintenance... oil change, fuel filter change, and air filter change. I'll check everything out and reply back. Thanks!
Lariet, Automatic
4.56 Gears
Brad777 is offline
post #4 of 6 (permalink) Old 04-19-2018, 08:35 PM
Sounds rich to me as I do not kno alot about the 6.4 but I will start learning soon enough is it anything like the 6.0 fuel system meaning oil primary fuel secondary in a sense?
Lovin6.0 is offline
post #5 of 6 (permalink) Old 08-19-2018, 02:51 PM
Couple of things,
There's no such thing as rich or lean in a diesel engine. It simply burns what you put in it. Black smoke is the result of too much fuel and not enough air (or not enough timing).
All the performance and all the fuel economy is locked in the tuning. These trucks will not make another up or get another mile per gallon unless they are told to do so.
Go back to the installer and find out who wrote the programming. SCT doesn't do off-road tuning. You have an SCT device, but it'll have someone's custom tuning on board. Find out who did the programming and have them fix it.
If you can't get any resolution, give us a call.
Doug Lewis
Ford Performance Specialists
351 Six Flags Pkwy SE
Mableton, GA 30126
770-949-7191
Not Racist, Not Violent
Just no longer Silent!
Question with Boldness.
2008 F-450 King Ranch w/4.30 gears
SCT Custom Tuning by FPS, Deleted, 16mpg
2001 F-250 Platinum Edition - Gone, but not forgotten
CIA, Garrett GTP38R, 4" Exhaust, SCT Custom Tuning by FPS
shoguy89 is offline
post #6 of 6 (permalink) Old 08-19-2018, 03:08 PM
Couple of things,
Doug Lewis
Mableton, GA 30126
770-949-7191
shoguy89 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
