7.3L CPS SEARCH AND EFFORT PAY OFF - Diesel Forum - TheDieselStop.com
'99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the '99 & up 7.3L Power Stroke Engine and Drivetrain forum.
 23Likes
post #1 of 410 (permalink) Old 09-09-2014, 06:03 PM Thread Starter
I have tried all the CPSs I could find.
I found this NAPA ELCHINs model and it's awesome.
I did have issue with it killing engine at idle only with wipers in the intermittent mode with it raining and then again with testing with garden hose.
I corrected this with ferrite chokes.
First things first.
Maryland dieselnick is offline
post #2 of 410 (permalink) Old 09-09-2014, 06:06 PM Thread Starter
This is the crank rotation velocity change report.
post #3 of 410 (permalink) Old 09-09-2014, 06:08 PM Thread Starter
This is the cylinder contribution test report.
post #4 of 410 (permalink) Old 09-09-2014, 06:16 PM Thread Starter
The choke beads are simple clamp on beads I got from Radio Shack.
First I tried the CPS ground, positive reference feed and signal as seen below but truck shut off after fifteen minutes with wipers wiping garden hose water or mist combinations while in the intermittent mode.
post #5 of 410 (permalink) Old 09-09-2014, 06:23 PM Thread Starter
So I remove drivers side wiper arm and the bezel below the arm.
I cut open wire harness to motor that is pictured here and place a choke on each wire and then one larger over the entire bundle of wire. I then taped up wires and chokes with electrical tape and then coated with Plasti Dip.
I then zip tied two ways as moving arm can rub against it.
post #6 of 410 (permalink) Old 09-09-2014, 06:30 PM
tinman13kup's Avatar
Why are cps's so friggin difficult? It seems all the "new and improved" ones have issues. I had to buy a new cps from the local parts store (BWD) and it advanced the injectors to the point of trying to skylight a piston above 1800rpm. i thought it was a fluke, but another guy I know with a SD said he had some issues (bad idm in the end), but initially replaced the cps (as I told him long ago) with a BWD and had the same problems.
The black one's were just fine. Why fix something that isn't broken?
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
______________________________________________
The first part to be thrown at these trucks should be a PSD compatible scanner
PM please. No Visitor Msg if you want a response anytime soon
tinman13kup is offline
post #7 of 410 (permalink) Old 09-09-2014, 06:42 PM Thread Starter
I then sprayed mist, sprayed heavy water, as well as let it wipe dry.
I repeated this test on EVERY increment on stalk for fifteen minutes.
I also tried spinning mode selector back and forth.
Well after an hour I declared victory as I could not kill it.
I took it on 3.5 hour trip to beach and it drove like a dream. It is quieter,smoother and just plain sweeter.
So I don't know If I caught the wire carrying the interference on the second attempt or if I created an accumulative effect.
It is not a lot of work and the small size chokes are in two packs for $2 and change.
The larger I used to cover the whole bundle is this guy and was about $3 and change for one.
Disregard the scrap of wire pictured next to it.
I hope this helps you benefit from a great running engine and gets rid of that bad feeling you have not passing the CCT test and just plain knowing your truck is not running the best it can.
Take Care
Nick
post #8 of 410 (permalink) Old 09-09-2014, 08:06 PM
Googs's Avatar
Good thread Nick thanks for sharing that, you could do some resurfacing on that work bench mate.
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
post #9 of 410 (permalink) Old 09-09-2014, 08:10 PM Thread Starter
You don't like my chic coffe table?
post #10 of 410 (permalink) Old 09-09-2014, 08:50 PM
Googs's Avatar
I love it mate , just don't tear the table cloth on the surface .ha
Googs is offline
post #11 of 410 (permalink) Old 09-09-2014, 09:23 PM
blue99stroker's Avatar
I need to go get some ferrite chokes. ive been using tin foil and its worked but I just never made a trip to radioshack haha
blue99stroker is offline
post #12 of 410 (permalink) Old 09-09-2014, 09:31 PM Thread Starter
Call before you go. They seem to have less and less of that stuff and more toys and phones.
Times are a changin.
post #13 of 410 (permalink) Old 09-09-2014, 09:38 PM
ya we have two or three in town so hopefully one of them has them. ya last time I went there they looked like a cell phone store lol
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
post #14 of 410 (permalink) Old 09-09-2014, 11:58 PM
hucorey's Avatar
Nick, have you heard of the latest oem CPS update. I heard its dark purple now. Supposed to be accurate as the old black one, but reliable like the grey one.
E99 CCLB 4X4, 230/100 PIS INJECTORS, KC38R TURBO, GEARHEAD STG 1 CAM, BILLET INTAKES, S&B CAI, D.E. 4" TURBO BACK EXH, 910 SPRINGS, ARP STUDS, MELLING LPOP, STEALTH 1.1 HPOP, IH BELLOWED UP PIPES, BTS TRANS, P.I. TORQUE CONV, PHP HYDRA, PHP TUNES, CNC FABRICATION HPOP LINES &HPX LINE, CNC FABRICATION 4 LINE FEED FUEL BOWL RETAIN KIT. RIDING ON 35" NITTO TERRA GRAPPLERS.
hucorey is offline
post #15 of 410 (permalink) Old 09-10-2014, 12:13 AM
Googs's Avatar
I don't think it's reports to good Corey.
Its the dark grey blue purple , Part number 1876736c91
The 1876736c91 is for the 94-96 7.3L engines. It is also sold as Ford P/N F4TZ-12K073-C.
Googs is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > '99 & up 7.3L Power Stroke Engine and Drivetrain > '99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
