7.3L CPS SEARCH AND EFFORT PAY OFF - Page 2 - Diesel Forum - TheDieselStop.com
'99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the '99 & up 7.3L Power Stroke Engine and Drivetrain forum.
 23Likes
post #16 of 410 (permalink) Old 09-10-2014, 12:13 AM
klhansen's Avatar
My Photos: (180)
Good info Nick
Thanks for posting it. I have a BWD CPS that I tried for one day in the rain. It was a total POS. I may have to try the choke trick and go back to my original CPS that was cutting out on me intermittently. Maybe the choke will make it more reliable.
), AIS,
regulated return,
klhansen is offline
post #17 of 410 (permalink) Old 09-10-2014, 02:06 AM
blue99stroker's Avatar
ive heard of guys having wiper issues with the originial cps as well. they recalled it so long ago seems like we all have high miles now.
ya it definately is not fun driving in the rain with it causing issues
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #18 of 410 (permalink) Old 09-10-2014, 03:36 AM
Googs's Avatar
Well i suppose the time will tell how these CPS's go in 7.3's
Are you guy's that have them installed hanging on the edge waiting for the truck to hiccup.
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
post #19 of 410 (permalink) Old 09-10-2014, 08:28 AM
SuperDutyTrooper's Avatar
My Photos: (6)
Nick, Your write up is great, but I'm unclear on exactly what chokes you used for this repair. Did you use the same pair of chokes on both the CPS pigtail and the wiper motor wire, and are the ones in my attached pic the ones that you got from Radio Shack?
And what do you mean by "The larger I used to cover the whole bundle is this guy and was about $3 and change for one." . . . seems like there is a word missing.
Thanks for a solution to this annoying CPS problem!
2000 F250 Ext Cab Longbed 7.3 4x4 ZF6 "The Pride of America" - AEM air filter, BTM exhaust, CNC Fab HPOP lines, CNC Fab 4-line stainless fuel lines, Fluidampr harmonic balancer, LuK improved clutch kit, Melling LPOP, DieselSite coolant filter, 203* thermostat in billet housing, 3 gauges (boost, pyro, fuel pressure) in pillar mount pod, AIH delete, EBPV delete, CCV mod, Zoodad mod, Glow Plug Relay relocation mod, Hutch mod, Harpoon mod, MileMarker manual locking hubs.
SuperDutyTrooper is offline
post #20 of 410 (permalink) Old 09-10-2014, 12:56 PM
NYB
How many wraps are you running through the ferrite bead?
I wouldn't think that the existing wires have enough length to run any wraps at all?
NYB is offline
post #21 of 410 (permalink) Old 09-10-2014, 01:23 PM
ya those are them. should go over the large ground wire on the firewall. or do like nick did and find the wire in the bundle by the wipers and shield it as well.
post #22 of 410 (permalink) Old 09-10-2014, 09:34 PM Thread Starter
NYB, I was worried about having to solder in more wire so I would have enough lengths to make the loops my electrical engineer friend told me I might have to do. I said nah ( to myself of course) I'm going to just clamp over and see if that does it first.
SuperDutyTrooper, those are the ones but there are different diameters, so pick up a few bags of the small and big sizes.
That red harness you see I had cut that open to expose the four or five wires going to wiper motor and then paced one of those bullet looking chokes on each wire. Then I used the larger box shaped one to clamp over the whole group of wires, note shape of red glob. The larger box one going over all is the white one pictured on table I picked up at electronics store on the way home. Radio shake has the but just black instead of white. You want a tight fit on the wire so you need the different sizes.
I electrical taped up wires and placed a piece of cardboard underneath and then brushed on Plasti dip.
Sorry this is a poor write up in the specifics department and photos and whatnot but this started the day before I took of for the beach. The truck had a couple minor misses you could only feel in the steering wheel in the line to the ATM. Ran home and scanned my dark blue International was going up and I was taking off in the morning so I just grabbed a NAPA Elichins, turned wipers on and it did not shut off. Ran test and saw the numbers I posted. Life's great take off, drives better than brand new. Second night down there and I am outside with them in intermitant mode outside a restaurant for ten minutes and bam!
I have tested with different volumes of water and mist in every single wiper detent, well over an hour and half. I cannot kill it now.
I have since rolled into local police station parking lot, no shut off. I repeated with fire department, no shut off. I repeated by going to a field with four communication towers lined with gadgets and dishes, no shut off.
xelerator likes this.
Maryland dieselnick is offline
post #23 of 410 (permalink) Old 09-10-2014, 09:38 PM Thread Starter
Kevin ford told the NTSB that the problem with the originals failing was a wire bundle separating internally. Perhaps they had interference issues as well, I never did, just the failure.
post #24 of 410 (permalink) Old 09-10-2014, 09:48 PM Thread Starter
Doing just the ground wires on fire wall did nothing even after placing one one each of the three cps wires.
I still had engine shut ifs after ten minutes of the water testing.
I WAS NOT successful in this till I placed one on each of the wires going into the wiper motor and then placing the larger one over the whole bundle of wire.
post #25 of 410 (permalink) Old 09-10-2014, 10:11 PM Thread Starter
I found two of the three bags with the part numbers and one of each of the three chokes I used.
I think with the picture of the three items and two of the part numbers one could go to web site and put it together.
Again the largest of the three is white in picture but will be black in Radio Shack brand.
post #26 of 410 (permalink) Old 09-10-2014, 11:31 PM Thread Starter
So this image is what I believe NYB had in mind and my electrical engineer buddy said I might have to do if doing just a straight run through did not work.
post #27 of 410 (permalink) Old 09-10-2014, 11:33 PM Thread Starter
Just doing this with the three different sizes worked, thankfully.
The wires are different gauges so you need the different sizes for a snug fit.
post #28 of 410 (permalink) Old 10-07-2014, 04:41 AM
This thread is what I've been looking for for about 12 years! Thanks for sharing your info and making life easier for others.
2002 F350 4x4 Crew Cab, Lariat,Standard Trans, sb, srw, 315 Cooper STT, aFe Stage II, Edge Juice w/ attitude monitor, 4" stainless exhaust, 4:10 gears, Auburn ECTD front, Auburn High Performance Limited Slip in back.
justnate is offline
post #29 of 410 (permalink) Old 10-07-2014, 12:18 PM Thread Starter
No problem, it's nice to have them running like glass and passing the CCT test.
post #30 of 410 (permalink) Old 10-07-2014, 12:49 PM Thread Starter
Supertrooper, I missed your post. Cut the tape open holding the wires together by the motor to seperate the wires. I placed a small choked( pictured) on each wire. I then used a larger one to cover all of the wires there. I then taped up with a high quality electrical tape. Place rags under it and brush on plasti dip. This is what I did at wiper motor.
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > '99 & up 7.3L Power Stroke Engine and Drivetrain > '99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
