CA SMOG F450/550 >14K GVWR Deadlines
75K views 36 replies 18 participants last post by  Fedup
#1 · (Edited)
If you own, operate, use, register, sit in, touch, sniff, think about, or happen to see an F-450 or F-550 drive down the road in the State of California, the following information may be of some interest to you.
__________
NEWLY Edited Note: After originally posting this, I went to Sacramento to attend a 4 hour training session in the EPA building taught by the actual CARB bureaucrats who actually dream up, draft and deliver these new diesel retrofit or retire regulations. I wanted to get the info straight from the horse's mouth, so to speak.
After learning a ton about the specific reporting and compliance requirements of commercial fleets, I went up to the CARB leaders and specifically asked about the requirements of recreational vehicle folks who simply bought an F-450 or F-550 to be able to tow and handle their fifth wheel or race car trailer or gooseneck horse trailer safely.
They said it is not their intent to go after this type of usage, and pointed me to the first and second pages of their dog eared play book, and they forwarded a pdf file of the same to the email address I gave them on the spot.
According to the "FINAL REGULATION ORDER" Division 3, Chapter 1, Section 2025, Paragraph (c) Subparagraph (12) "Exemptions: This regulation does not apply to: Trucks with a GVWR of 19,500 or less with a pick-up bed used exclusively for personal, non-commercial, or non-governmental use."
So if you have an F-450 pick up or an F-550 with a pick-up bed conversion such as what Manning, Fontaine, Royal, UBW, and others have made... and this heavy hauling pickup is used exclusively for personal use and not for trade or commerce, then that vehicle falls under the exemption cited above.
__________
If the F-450/550 has a flat bed or stake bed or other commerically oriented body that would also typically require it to stop at the scales, then read on:
1. Trucks over 14,000 lbs. GVWR are exempt from the biennial smog checks.
2. Trucks over 14.000 lbs. GVWR are required to be brought into compliance with 2010 level emissions eventually.
3. Trucks over 26,000 lbs. GVWR are also subject to annual fleet reporting requirements, meeting a compliance schedule, or phase in of retrofits if elected, or early retirement.
4. Trucks between 14K and 26K do not have to be reported, and have a longer period of time before retrofitting or retirement is mandated. HOWEVER....
5. Fleets that have a mix of trucks both over and under 26K GVWR need to report ALL trucks in their fleets that are over 14K if electing to not follow the CARB compliance schedule STRICTLY and instead want to use the more lenient phase in option schedules.
6. There are many more specifics to the CARB requirements that this post is not intended to address. Please refer to the CARB website f you have a truck over 26K GVWR (and there is no F-450 or 550 that falls in that category, as even the heaviest duty F-550 is still only 19.5K GVWR, regardless of gross COMBINED rating).
7. There is no requirement to retrofit F-450/550s with aftertreatment particulate matter filter systems.
8. Heavier trucks (over 26k GVWR) must be retrofitted with particulate matter filter systems by deadlines that loom in 2012, 2013, 2014, 2015, and 2017. However, these deadlines do not apply to F-450/550 medium duty trucks between 14K and 26K GVWR.
9. The compliance strategies specified by the CARB are the same for all F-450s and F-550s from 1998 through 2009. The DEADLINE for compliance DIFFERS, but the strategy is the same. CARB has four options for compliance in heavier duty trucks, but for vehicles under 26K GVWR, the options all boil down to one: Replacement with a 2010 model year or newer engine by a specified date. (Date chart below).
1998 - Replace with 2010 MY or newer engine by January 1, 2018
1999 - Replace with 2010 MY or newer engine by January 1, 2019
2000 - Replace with 2010 MY or newer engine by January 1, 2020
2001 - Replace with 2010 MY or newer engine by January 1, 2020
2002 - Replace with 2010 MY or newer engine by January 1, 2020
2003 - Replace with 2010 MY or newer engine by January 1, 2020
2004 - Replace with 2010 MY or newer engine by January 1, 2021
2005 - Replace with 2010 MY or newer engine by January 1, 2021
2006 - Replace with 2010 MY or newer engine by January 1, 2021
2007 - Replace with 2010 MY or newer engine by January 1, 2023
2008 - Replace with 2010 MY or newer engine by January 1, 2023
2009 - Replace with 2010 MY or newer engine by January 1, 2023
2010 - Have a cigar! You are already in compliance.
Note that the deadline is the same for engine model years 2000-2003 (2020), and the same for model years 2004-2006 (2021), and the same for model years 2007-2009 (2023).
Also note that no differentiation is made for the 2003 model year that had both the 7.3L as well as the 6.0L engine.
Note further that the deadline is the same for the 2007 6.0L engine, versus the newer 2008 6.4L engine.
And fnally note that the 2010 6.4L engine gets a pass, while not substantially different than the 2008 and 2009 engines that are forced to be retrofitted (with what? The same engine?) in 2023.
Obviously, if you are subject to these regulations, you need to do your own due diligence in determing how to comply. I'm not an expert, I am not liable for your reliance on this information. I posted what I researched online, as well as at what I learned in the CARB training school, in the spirit of sharing tidbits and fostering open helpful discussion with other members who are similarly situated.
Reference: "FINAL REGULATION ORDER" As provided by CARB on December 29, 2011
http://www.arb.ca.gov/msprog/onrdiesel/documents/TBFinalReg.pdf
See less See more
#2 ·
Sure stinks to be in California:icon_rolleyes:. Here's the T.O.M. route for CA smog compliance, since you will never satisfy the gov't there until you drive a prius : MOVE:lol:
#4 ·
I've posted on this particular forum section, as emissions is an engine related issue, and the 7.3L engine is likely the only motor that will last long enough to be worried about retrofitting in 2020! ;)
Good info.:thumbsup:
If you'd like, I can move it up into the 7.3L E&D FAQ subforum, but it's definitely appropriate here. Let me know.
I am amazed at how often I've googled something I wanted to know, and the first and most appropriate hit was one of my very own posts (under a different user name) that answered all of my questions! How did I forget? How did I know it in the first place? I'll never know the answer to either of those questions.
:lol:
I resemble that remark. It seems like some days I'm in danger of forgetting my name.
How we remember the littlest, most obscure things, and forget the big stuff is one of life's mysteries.
#5 ·
Sure. Absolutely move it up into the FAQ. I'd be honored. The info should be relevant and timely for the next 10 years!
A lot of F-450/550 owners in California may not realize how the new emissions regulations impact them yet. I know I was confused by them.
My VIN ends in an odd number, so last year I wasn't sure whether I didn't have to smog on my last registration renewal because of the that (VINs ending in even numbers got hit up for smog testing last year, and VINs ending in odd numbers get hit this year) or did I not have to smog because I was over 14K gvwr. I suspected the latter, but feared the former. Part of the research was to confirm the latter. No test required.
However, that seemed worse... because that would mean retrofitting, at a cost of $5,000 to $10,000 per truck, so I heard. That was worrisome, as the trucks depreciate down to that level. So the other part of the research was to confirm which type of trucks had to retrofit, and which simply had to retire. Ours simply have to retire (to green pastures... ie, other states perhaps), and we have a reasonable time to use the life left in the vehicle.
#6 ·
Here is something else of interest that is in the works.
Scroll down to the center of the page....look for the 5th bullet.
NEW BIT PROGRAM
"The inspection will include lower GVWR vehicles (10,000 lbs. or more with 2-axles) that were previously not subject to BIT. Now ALL vehicles that require a MCP would also be subject to BIT fees and inspections."
#7 ·
Looking at the costs of retrofitting....
$11,000 for passive system
or
$20,000 for active system
That's per truck.
Obviously, the cost to retrofit comes close to meeting or exceeding the residual value of the chassis. (not counting the second unit upfit body, which can be transferred to a new chassis)
So retrofitting is not feasible.
#8 ·
Can we get a link to an official site with this info? This kind of stuff REALLY makes me mad! I need to find a way to incorporate in a different state and register my vehicles there.
  • Like
Reactions: mattt
#9 · (Edited)
#10 ·
Thanks. I read most of everything on those links, but I still can't determine if my E450 motorhome is covered under any of these regulations. I sure hope not!
#11 ·
You should (notice I said should :icon_wink: ) be OK since a motorhome is registered as a "house car" and does not fit into the truck or bus categories. I do know that they are exempt from all of the CHP rules and regs for commercial vehicles that I deal with daily.
To put your mind at ease, I'd dial up CARB's 800 number or shoot them an email.
#12 ·
I wonder what they will think of my 1999 Peterbilt 385 that is registered as a Motorhome in Montana, LOL! Screw the Commiefornians!
Joe
#14 ·
If you are getting a 2014, your new rig will have the DPF and Urea system installed from the factory. You are good to go (until CARB decides the change the rules again)
#15 ·
Good heavens! Do those ting bats stay up at night thinking of ways to make life more difficult?
And I thought Taxachusetts was bad......
#16 ·
I know this post is old but I need some clarification. I'm pretty sure I understand but would like to know before I buy another truck.
I'm thinking of getting an 08-10 f450 and it will be used basically as any other truck I've owned, damn near a daily driver. It will be treated just like it was an f150. Knowing that, will I have any issues in the future regarding smog or any other bs, like this retrofitting nonsense? Or am I in the clear to do whatever I see fit with this truck?
#18 ·
the new trucks come equipped with dpfs and CAT's, so no retrofitting
you will be fine, might have to replace the exhaust filter after awhile
#19 ·
Hey I need to bring this topic back up.
I just bought a 2010 F450 out of state. This year F450 is smog exempt since the GVWR is 14500.
My question is do I still have to smog it initially to get it registered here in Cali?
I did buy it from a dealership in VA and had it shipped here. They said it was unmodified, but I took it to get smogged only to find out I'm missing the emissions equipment (CAT, DPF). So I'm in the process of figuring it all out.
What's anyones thoughts on this?
#21 ·
Old thread resurrection.....is there any way possible now or coming in the future from Ford or anyone else to retrofit a "2010 or newer engine" in my 2006 F450 6.0 diesel?
These overpaid, lazy, arrogant CARB bureaucRATS are dreaming Lucy in the sky with diamonds. They are ON DRUGS, or their Momma dropped them on their head as a baby, or most likely BOTH. Any FOOL who would vote for a DemoncRAT needs to kill themselves! This nonsense with DemonRAT CA has got to stop! Those of us decent Americans in CA have had enough. Not business friendly regulation...not even a law.
#33 ·
These overpaid, lazy, arrogant CARB bureaucRATS are dreaming Lucy in the sky with diamonds. They are ON DRUGS, or their Momma dropped them on their head as a baby, or most likely BOTH. Any FOOL who would vote for a DemoncRAT needs to kill themselves! This nonsense with DemonRAT CA has got to stop! Those of us decent Americans in CA have had enough. Not business friendly regulation...not even a law.[/
Is this a pickup?
What is the GVWR?
What is your use of the vehicle?
#22 ·
#23 ·
Thank you. Are any of the Cummins considered a 2010 model year or newer engine? Does that company offer the engine itself too or is that up to the buyer to find? Most everything I saw on the link was for 98-02 if I remember correctly. To be "legal" in CA after 2021, a 2006 truck needs to have a 2010 or newer engine installed.
#24 ·
You have to find your own engine. If you scroll down a little farther, you will see that they offer different parts for installing different years of Cummins engines, not only 98-02. They provide the parts that you will need to put it into the ford truck. There are several 2010 or newer Cummins engines currently for sale on ebay.
#25 ·
Right. Destroked supports Cummins motors up to 2012 including the Cummins 6.7 engine.
#27 ·
Not really. There are no companies that support the upgrade of the International 6.4 or the Ford 6.7 into your chassis. Plus, you'd have to be a special kind of masochist to want either of those two motors in the first place. The 6.4 is a time bomb waiting to go off and the early 6.7 motors are just about as bad. The later 6.7 motors look better, but a complete motor would probably set you back more than you'd want to spend and you'd still be nowhere near the reliability of the Cummins.
#28 ·
Thank you. Yes the 6.4 I would avoid like the plague. However, I thought I had heard okay things about the newer 6.7? I may also consider just getting a newer truck that is 2010 or later. Been looking on and off and found a 2015 with the 6.7. I am very familiar with my current 6.0 and how to deal with all it's shortcomings. Does the 6.7 have it's own list of problems with relevant solutions? Am I reading your reply correctly that a complete Ford motor would set you back more than a complete Cummins motor.....if the Cummins is a better engine, then why is it available for less coin? Seems counter intuitive.
If the choice was wide open, would you opt for Cummins retrofit into an 06-07 chassis or go for the new Ford 6.7?
#29 ·
If I had a billion dollars in the bank and had the choice between the Cummins in a Ford body or a Ford 6.7, I’d pick the Cummins. That would be even more important if I didn’t have the throwaway money to do the job twice. The Cummins is a million mile motor.
#30 · (Edited)
Used to be......
Currently heard of more 6.7 psd's at/over a mill vs 6.7 cumminGs.
And the early 6.7's were nowhere near as bad as a 6.4.
Sent from my SAMSUNG-SM-G930A using Tapatalk
#31 ·
I'd be impressed to see a Ford 6.7 with a million miles on the original motor. The Cummins 6.7 through 2012 apparently avoided the DEF/DPF setup. If you read any of the Cummins forums, the issues started in 2013 when that headache was added. I suspect that is why Destroked cut their swap kits off with the 2012 Cummins engines.
  • Like
Reactions: mattt
#32 ·
Anyone been following recent developments on this front? It appears there may have been a lawsuit that didn't go in CARB's favor. Thank God for that. Are the regs that are detailed on page 1 of this thread still accurate or is updating necessary in this thread?
Thanks in advance.
#34 ·
Really?
You are thankful that the lawsuit, and the appeal that CARB filed and fought for after losing the first time around, didn't go in CARB's favor?
Why?
Why are you so thankful?
Because it's CARB? And CARB lost?
You may not realize this, but when CARB lost, the everyday hardworking Joe lost. Small businesses lost. And California consumers lost too, because the prices of every good and service delivered or facilitated by a heavy duty diesel truck, which is every thing we buy, and every road it is delivered on... lost.
CARB fought that lawsuit for US, not for them. Back in 2010, when the heavy duty diesel regulations were originally enacted, the regulators did not fully comprehend how financially difficult it would be for small business to migrate their fleets to the adoption of new trucks by 2020. The folks at CARB are very smart, so they worked out all the math to prove that small business could afford it. But that math was based on the new trucks actually WORKING, not breaking down on the side of the road. And that math was based on long haul, line haul trucking, not 3 mile round trips between repaving a city street and the asphalt plant, where the emissions equipment never gets hot enough to function, and thus clogs up.
It took about 3 years for the CARB to finally realize that they had demanded a standard that was physically, financially, and functionally impossible to achieve. So in 2014, the CARB relaxed the rules.
For example, as initially defined beginning in 2010, the low use exemption was originally limited to 1,000 miles per year in California, and 5,000 miles per year total, where the rest of those miles had to be out of state, with fuel receipts, deliveries of laden paperwork, log books, and scale tickets to prove out of state usage. Compliance reporting began phasing in, based on fleet size and other particulars, in 2011, and by 2013, most fleets had to have begun reporting. At the same time, diesel emissions systems of the costly new trucks that California businesses were being required to convert to were breaking down during those initial years between 2010-2013, costing millions of dollars, due to construction projects being hamstrung by failing trucking equipment.
In keeping with the narrow focus of this one example, CARB relaxed the compliance rules in 2014, by removing the out of state requirement for the remaining 4,000 miles of the 5,000 mile low use limit, and thus permitting all 5,000 miles to be driven within California. This enabled businesses to continue to use very short haul dump trucks and crane haulers and concrete trucks and pump trucks... all of which are not driven very far, fast, or long... and all of which must idle a lot as they pump concrete, dump into paving machines, etc. CARB's relaxation of the rules in 2014 enabled small business to continue to meet California's need to maintain streets and roads and parking lots and driveways in both the public and private sector. It would otherwise cost $175,000 per dump truck, and more sophisticated concrete pump trucks can run up to a half million dollars each. That kind of equipment can't be amortized over the short few years the state initially required businesses to replace it by.
CARB saw the problems, and tried to fix it.
But one big well heeled conglomerate trucking company got jealous, and cried foul. This giant trucking fleet, that operates thousands of vehicles, and who had the resources to replace their fleet per the original replacement schedule (this schedule is not shown on the first page of this thread as it applies to trucks 26,000 GVWR and over, and my original post on this issue was only directed toward TDS members with Ford diesel light truck in the 14,000 to 19,500 GVWR range) because this company replaces their fleet regularly anyway... felt that CARB relaxing the rules midway through the game was unfair to them, because they had hoped to gain economic advantage over their competitors who couldn't afford to replace an aging, and soon to be non compliant fleet.
If the smaller businesses aging fleet falls out of compliance, that leaves more business to be picked up by the big giant fleet that has all new trucks which are in compliance. The CARB's relaxation of the rules in 2014 upset the large company's plan to usurp the smaller businesses clients, by virtue of the smaller business not being able to afford to replace their fleet at the same rate that the large company could do. So the large company sued CARB, to force CARB to reenact the more rigorous regulations that were originally brought into effect in 2010. CARB fought back, realizing that the greater good for the state was in the relaxation of the rules that were originally too aggressively implemented, given the cost and abysmal failure rate of the emissions technology.
CARB lost. CARB appealed to a higher court. CARB lost again.
It took four years to resolve this matter. By spring of 2018, the matter was final, and effective January 1, 2019, the original fleet compliance schedule defined in 2010, was reenacted. Please keep in mind, that 99% of what I'm discussing involves rules and regulations that I haven't discussed, because they do not pertain to vehicles under 26,000 GVWR. The only exception is the low use exemption, which CAN apply to F-450 and F-550 commercial vehicles with diesel engines, that fall within the years identified on the original post on page one of this thread.
Before CARB was sued, it would have been possible for a commercial operator of an F-450/550 service truck or tow truck or flat bed or utility bucket truck which had a diesel engine older than 2010... to be able to continue to operate that truck in California under the low use exemption, for up to 5,000 miles per year. There are quite a few folks with drill rigs and other types of equipment that doesn't get used that much, but is necessary to have on the few occasions where it is needed, and yet would be unaffordable to replace. When CARB lost, these folks lost too. Now the in state mileage restriction to qualify for a low use exemption is back down to just 1,000 in state miles per year. Thanks to one big business suing CARB.
I can see the big business argument... not fair changing the rules in the middle of the game. The "game" was the 10 year gradual phase in period between 2010 and 2020, or really, between 2011 and 2023. But I can also see CARB's argument... which was essentially an admission that they over reached at the outset, and based on the feedback of the affected parties, wanted to scale back the requirements just a little bit in order to help everyone fall into compliance, which really helps discourage people from ignoring the laws altogether and rolling the dice by cheating.
Only now, they can't cheat so easily, due to the database matrix matching that all branches of state government have been coalescing and sharing since 2015. It will soon not be possible to register a non compliant truck. This is already happening for owners of trucks that are scheduled to be repowered or retired by January 1, 2020. The notices are already going out now... "Not eligible for registration renewal".
Yes, the regs detailed on page 1 of this thread are still accurate, and for that you may or may not want to "Thank God", because it was thanks to CARB losing the lawsuit brought against them by one big trucking firm that any hope for changing that original schedule, and any hope for gaining a reasonably viable exemption from that original schedule... vanished.
If you are an effected owner of a 1988 through 1997 F-SuperDuty (aka OBS F-450), then you already got the letter and had to repower or retire that truck.
If you are an effected owner of a 1999 through 2003 F-450/F-550 7.3L, then you are getting letters right now, along with notices that your registration will not be renewed without a new engine that is 2010 or newer. For the fleet I advised to buy no later than 2003 F-550's while the 7.3L could still be ordered, to avoid the 6.0L, which I was warned in 2001 would be a disaster (and the insider who warned me was right)... the 2000-2003 trucks are still running without problems. But they will all be sold (outside of CA) this fall, as we have just this week taken delivery of 2019 replacement F-550s. I just now went over and drove a naked cab chassis around the back lot, as it awaits a special service body being built for it. The replacement of these under 26K trucks had to wait until the very last year (this year), because the previous several years (and all available funds for financing) have been spend on replacing the over 26K trucks, which had a much earlier compliance schedule.
Likewise, if you do happen to have a 6.0L, or a 6.4L, your time will also come, with only one more year (January 1, 2021) for model years up to 2007, and three more years (January 1, 2023) for model years 2008 and 2009.
It will hit the fan by within this year, as the folks who ignored all the notices from CARB over the last 10 years will suddenly find that they can no longer register their 2000 through 2003 diesel trucks that are over 14,000 GVWR in the state of California unless they repower with a 2010 or newer engine and emissions system. This regulation does not apply to pickup trucks.
You have insufficient privileges to reply here.
