CA SMOG F450/550 >14K GVWR Deadlines - Diesel Forum - TheDieselStop.com
'99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the '99 & up 7.3L Power Stroke Engine and Drivetrain forum.
 3Likes
post #1 of 35 (permalink) Old 07-10-2011, 04:38 PM Thread Starter
NYB
If you own, operate, use, register, sit in, touch, sniff, think about, or happen to see an F-450 or F-550 drive down the road in the State of California, the following information may be of some interest to you.
__________
NEWLY Edited Note: After originally posting this, I went to Sacramento to attend a 4 hour training session in the EPA building taught by the actual CARB bureaucrats who actually dream up, draft and deliver these new diesel retrofit or retire regulations. I wanted to get the info straight from the horse's mouth, so to speak.
After learning a ton about the specific reporting and compliance requirements of commercial fleets, I went up to the CARB leaders and specifically asked about the requirements of recreational vehicle folks who simply bought an F-450 or F-550 to be able to tow and handle their fifth wheel or race car trailer or gooseneck horse trailer safely.
They said it is not their intent to go after this type of usage, and pointed me to the first and second pages of their dog eared play book, and they forwarded a pdf file of the same to the email address I gave them on the spot.
According to the "FINAL REGULATION ORDER" Division 3, Chapter 1, Section 2025, Paragraph (c) Subparagraph (12) "Exemptions: This regulation does not apply to: Trucks with a GVWR of 19,500 or less with a pick-up bed used exclusively for personal, non-commercial, or non-governmental use."
So if you have an F-450 pick up or an F-550 with a pick-up bed conversion such as what Manning, Fontaine, Royal, UBW, and others have made... and this heavy hauling pickup is used exclusively for personal use and not for trade or commerce, then that vehicle falls under the exemption cited above.
__________
If the F-450/550 has a flat bed or stake bed or other commerically oriented body that would also typically require it to stop at the scales, then read on:
1. Trucks over 14,000 lbs. GVWR are exempt from the biennial smog checks.
2. Trucks over 14.000 lbs. GVWR are required to be brought into compliance with 2010 level emissions eventually.
3. Trucks over 26,000 lbs. GVWR are also subject to annual fleet reporting requirements, meeting a compliance schedule, or phase in of retrofits if elected, or early retirement.
4. Trucks between 14K and 26K do not have to be reported, and have a longer period of time before retrofitting or retirement is mandated. HOWEVER....
5. Fleets that have a mix of trucks both over and under 26K GVWR need to report ALL trucks in their fleets that are over 14K if electing to not follow the CARB compliance schedule STRICTLY and instead want to use the more lenient phase in option schedules.
6. There are many more specifics to the CARB requirements that this post is not intended to address. Please refer to the CARB website f you have a truck over 26K GVWR (and there is no F-450 or 550 that falls in that category, as even the heaviest duty F-550 is still only 19.5K GVWR, regardless of gross COMBINED rating).
7. There is no requirement to retrofit F-450/550s with aftertreatment particulate matter filter systems.
8. Heavier trucks (over 26k GVWR) must be retrofitted with particulate matter filter systems by deadlines that loom in 2012, 2013, 2014, 2015, and 2017. However, these deadlines do not apply to F-450/550 medium duty trucks between 14K and 26K GVWR.
9. The compliance strategies specified by the CARB are the same for all F-450s and F-550s from 1998 through 2009. The DEADLINE for compliance DIFFERS, but the strategy is the same. CARB has four options for compliance in heavier duty trucks, but for vehicles under 26K GVWR, the options all boil down to one: Replacement with a 2010 model year or newer engine by a specified date. (Date chart below).
1998 - Replace with 2010 MY or newer engine by January 1, 2018
1999 - Replace with 2010 MY or newer engine by January 1, 2019
2000 - Replace with 2010 MY or newer engine by January 1, 2020
2001 - Replace with 2010 MY or newer engine by January 1, 2020
2002 - Replace with 2010 MY or newer engine by January 1, 2020
2003 - Replace with 2010 MY or newer engine by January 1, 2020
2004 - Replace with 2010 MY or newer engine by January 1, 2021
2005 - Replace with 2010 MY or newer engine by January 1, 2021
2006 - Replace with 2010 MY or newer engine by January 1, 2021
2007 - Replace with 2010 MY or newer engine by January 1, 2023
2008 - Replace with 2010 MY or newer engine by January 1, 2023
2009 - Replace with 2010 MY or newer engine by January 1, 2023
2010 - Have a cigar! You are already in compliance.
Note that the deadline is the same for engine model years 2000-2003 (2020), and the same for model years 2004-2006 (2021), and the same for model years 2007-2009 (2023).
Also note that no differentiation is made for the 2003 model year that had both the 7.3L as well as the 6.0L engine.
Note further that the deadline is the same for the 2007 6.0L engine, versus the newer 2008 6.4L engine.
And fnally note that the 2010 6.4L engine gets a pass, while not substantially different than the 2008 and 2009 engines that are forced to be retrofitted (with what? The same engine?) in 2023.
Obviously, if you are subject to these regulations, you need to do your own due diligence in determing how to comply. I'm not an expert, I am not liable for your reliance on this information. I posted what I researched online, as well as at what I learned in the CARB training school, in the spirit of sharing tidbits and fostering open helpful discussion with other members who are similarly situated.
Reference: "FINAL REGULATION ORDER" As provided by CARB on December 29, 2011
http://www.arb.ca.gov/msprog/onrdies...TBFinalReg.pdf
NYB is offline
post #2 of 35 (permalink) Old 07-10-2011, 05:30 PM
tinman13kup's Avatar
Sure stinks to be in California. Here's the T.O.M. route for CA smog compliance, since you will never satisfy the gov't there until you drive a prius : MOVE
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
______________________________________________
The first part to be thrown at these trucks should be a PSD compatible scanner
PM please. No Visitor Msg if you want a response anytime soon
tinman13kup is offline
post #3 of 35 (permalink) Old 07-10-2011, 05:41 PM Thread Starter
NYB
That's the thing though... I DO drive a Prius. Been driving a Prius for the last 6 years. That's still not enough.
NYB is offline
post #4 of 35 (permalink) Old 07-10-2011, 06:00 PM
klhansen's Avatar
My Photos: (180)
Originally Posted by NYB View Post
I've posted on this particular forum section, as emissions is an engine related issue, and the 7.3L engine is likely the only motor that will last long enough to be worried about retrofitting in 2020!
Good info.
If you'd like, I can move it up into the 7.3L E&D FAQ subforum, but it's definitely appropriate here. Let me know.
I am amazed at how often I've googled something I wanted to know, and the first and most appropriate hit was one of my very own posts (under a different user name) that answered all of my questions! How did I forget? How did I know it in the first place? I'll never know the answer to either of those questions.
I resemble that remark. It seems like some days I'm in danger of forgetting my name. How we remember the littlest, most obscure things, and forget the big stuff is one of life's mysteries.
), AIS,
regulated return,
klhansen is offline
post #5 of 35 (permalink) Old 07-11-2011, 12:01 AM Thread Starter
NYB
Originally Posted by klhansen View Post
Good info.
Sure. Absolutely move it up into the FAQ. I'd be honored. The info should be relevant and timely for the next 10 years!
A lot of F-450/550 owners in California may not realize how the new emissions regulations impact them yet. I know I was confused by them.
My VIN ends in an odd number, so last year I wasn't sure whether I didn't have to smog on my last registration renewal because of the that (VINs ending in even numbers got hit up for smog testing last year, and VINs ending in odd numbers get hit this year) or did I not have to smog because I was over 14K gvwr. I suspected the latter, but feared the former. Part of the research was to confirm the latter. No test required.
However, that seemed worse... because that would mean retrofitting, at a cost of $5,000 to $10,000 per truck, so I heard. That was worrisome, as the trucks depreciate down to that level. So the other part of the research was to confirm which type of trucks had to retrofit, and which simply had to retire. Ours simply have to retire (to green pastures... ie, other states perhaps), and we have a reasonable time to use the life left in the vehicle.
NYB is offline
post #6 of 35 (permalink) Old 07-24-2011, 05:04 PM
NP
My Photos: (10)
Here is something else of interest that is in the works.
Scroll down to the center of the page....look for the 5th bullet.
NEW BIT PROGRAM
"The inspection will include lower GVWR vehicles (10,000 lbs. or more with 2-axles) that were previously not subject to BIT. Now ALL vehicles that require a MCP would also be subject to BIT fees and inspections."
__________________________________________________ ________________
2000 SD CC PSD 4X4 Lariat, 156 WB, Island Blue & Harvest Gold, AIC, Autometer Pyro, Isspro Boost gauge, Banks Monster Exhaust, AIS Filter Kit, Racor CCV3550, 2007 grille, Grover Organtone Air Horns, 02 headlights, 2012 rear bumper, hitch, tail lights & mirrors. Ordered 11/23/99, Built 01/13/00, shipped 01/14/00, Delivered 2/2/00. (29,815miles on the odometer as of 6-22-2019)
NP is offline
post #7 of 35 (permalink) Old 07-25-2011, 04:59 PM Thread Starter
NYB
Looking at the costs of retrofitting....
$11,000 for passive system
or
$20,000 for active system
That's per truck.
Obviously, the cost to retrofit comes close to meeting or exceeding the residual value of the chassis. (not counting the second unit upfit body, which can be transferred to a new chassis)
So retrofitting is not feasible.
NYB is offline
post #8 of 35 (permalink) Old 08-14-2011, 08:53 AM
jgorm's Avatar
Can we get a link to an official site with this info? This kind of stuff REALLY makes me mad! I need to find a way to incorporate in a different state and register my vehicles there.
mattt likes this.
E450 7.3 PSD in a Bigfoot 24' motorhome.
Acquired parts for the intercooler mod
Intake spider
jgorm is offline
post #9 of 35 (permalink) Old 08-14-2011, 09:57 AM
NP
My Photos: (10)
Diesel Activities - Mobile Vehicles and Equipment CARB's page for diesel vehicles
Truck Stop <----click the link, a new page will open, then click on the picture of the white conventional Freightliner. CARB's handy little tool that helps you determine if the regs apply to you.
Diesel Activities - Mobile Vehicles and Equipment CARB's home page for all diesel activity.
NP is offline
post #10 of 35 (permalink) Old 08-14-2011, 10:14 AM
jgorm's Avatar
Thanks. I read most of everything on those links, but I still can't determine if my E450 motorhome is covered under any of these regulations. I sure hope not!
Intake spider
jgorm is offline
post #11 of 35 (permalink) Old 08-14-2011, 10:43 AM
NP
My Photos: (10)
You should (notice I said should ) be OK since a motorhome is registered as a "house car" and does not fit into the truck or bus categories. I do know that they are exempt from all of the CHP rules and regs for commercial vehicles that I deal with daily.
To put your mind at ease, I'd dial up CARB's 800 number or shoot them an email.
NP is offline
post #12 of 35 (permalink) Old 12-16-2011, 01:33 AM
I wonder what they will think of my 1999 Peterbilt 385 that is registered as a Motorhome in Montana, LOL! Screw the Commiefornians!
Joe
mattt likes this.
1997 F350 XLT CC DRW LWB LS 4.10 Tow Package 6x4 Dark Blue Metallic, Auto, 7.3L
1FTJW35F5VEA10132
1999 F350 4x2 Oxford White w/ Grey Super Cab, SRW, L.B., 7.3 w/ Auto, Ltd. Slip 3.73, Cmpr Pkg., Factory Aluminum Rims, T/S Mir.
1FTSX30F3XEC85932
SprintCarCowboy is offline
post #13 of 35 (permalink) Old 08-26-2013, 03:55 PM
Has anything changed since this was first posted?? I just ordered a 2014 F-450
AvgGuy is offline
post #14 of 35 (permalink) Old 08-26-2013, 08:27 PM
NP
My Photos: (10)
If you are getting a 2014, your new rig will have the DPF and Urea system installed from the factory. You are good to go (until CARB decides the change the rules again)
NP is offline
post #15 of 35 (permalink) Old 08-27-2013, 05:26 AM
Boston Mark's Avatar
Good heavens! Do those ting bats stay up at night thinking of ways to make life more difficult?
And I thought Taxachusetts was bad......
1999.5 F350 Dually X-Cab.
DP Tuner 80 hp econo burn.
Franz bypass filter.
Amber light bar rear.
LED flashing lights front.
Ford Green Lable rebuilt motor.
Rebuilt transmission.
Pushing 400,000 miles and running strong!
I love this truck.
Boston Mark is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > '99 & up 7.3L Power Stroke Engine and Drivetrain > '99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
