If you own, operate, use, register, sit in, touch, sniff, think about, or happen to see an F-450 or F-550 drive down the road in the State of California, the following information may be of some interest to you.
__________
NEWLY Edited Note: After originally posting this, I went to Sacramento to attend a 4 hour training session in the EPA building taught by the actual CARB bureaucrats who actually dream up, draft and deliver these new diesel retrofit or retire regulations. I wanted to get the info straight from the horse's mouth, so to speak.
After learning a ton about the specific reporting and compliance requirements of commercial fleets, I went up to the CARB leaders and specifically asked about the requirements of recreational vehicle folks who simply bought an F-450 or F-550 to be able to tow and handle their fifth wheel or race car trailer or gooseneck horse trailer safely.
They said it is not their intent to go after this type of usage, and pointed me to the first and second pages of their dog eared play book, and they forwarded a pdf file of the same to the email address I gave them on the spot.
According to the "FINAL REGULATION ORDER" Division 3, Chapter 1, Section 2025, Paragraph (c) Subparagraph (12) "Exemptions: This regulation does not apply to: Trucks with a GVWR of 19,500 or less with a pick-up bed used exclusively for personal, non-commercial, or non-governmental use."
So if you have an F-450 pick up or an F-550 with a pick-up bed conversion such as what Manning, Fontaine, Royal, UBW, and others have made... and this heavy hauling pickup is used exclusively for personal use and not for trade or commerce, then that vehicle falls under the exemption cited above.
__________
If the F-450/550 has a flat bed or stake bed or other commerically oriented body that would also typically require it to stop at the scales, then read on:
1. Trucks over 14,000 lbs. GVWR are exempt from the biennial smog checks.
2. Trucks over 14.000 lbs. GVWR are required to be brought into compliance with 2010 level emissions eventually.
3. Trucks over 26,000 lbs. GVWR are also subject to annual fleet reporting requirements, meeting a compliance schedule, or phase in of retrofits if elected, or early retirement.
4. Trucks between 14K and 26K do not have to be reported, and have a longer period of time before retrofitting or retirement is mandated. HOWEVER....
5. Fleets that have a mix of trucks both over and under 26K GVWR need to report ALL trucks in their fleets that are over 14K if electing to not follow the CARB compliance schedule STRICTLY and instead want to use the more lenient phase in option schedules.
6. There are many more specifics to the CARB requirements that this post is not intended to address. Please refer to the CARB website f you have a truck over 26K GVWR (and there is no F-450 or 550 that falls in that category, as even the heaviest duty F-550 is still only 19.5K GVWR, regardless of gross COMBINED rating).
7. There is no requirement to retrofit F-450/550s with aftertreatment particulate matter filter systems.
8. Heavier trucks (over 26k GVWR) must be retrofitted with particulate matter filter systems by deadlines that loom in 2012, 2013, 2014, 2015, and 2017. However, these deadlines do not apply to F-450/550 medium duty trucks between 14K and 26K GVWR.
9. The compliance strategies specified by the CARB are the same for all F-450s and F-550s from 1998 through 2009. The DEADLINE for compliance DIFFERS, but the strategy is the same. CARB has four options for compliance in heavier duty trucks, but for vehicles under 26K GVWR, the options all boil down to one: Replacement with a 2010 model year or newer engine by a specified date. (Date chart below).
1998 - Replace with 2010 MY or newer engine by January 1, 2018
1999 - Replace with 2010 MY or newer engine by January 1, 2019
2000 - Replace with 2010 MY or newer engine by January 1, 2020
2001 - Replace with 2010 MY or newer engine by January 1, 2020
2002 - Replace with 2010 MY or newer engine by January 1, 2020
2003 - Replace with 2010 MY or newer engine by January 1, 2020
2004 - Replace with 2010 MY or newer engine by January 1, 2021
2005 - Replace with 2010 MY or newer engine by January 1, 2021
2006 - Replace with 2010 MY or newer engine by January 1, 2021
2007 - Replace with 2010 MY or newer engine by January 1, 2023
2008 - Replace with 2010 MY or newer engine by January 1, 2023
2009 - Replace with 2010 MY or newer engine by January 1, 2023
2010 - Have a cigar! You are already in compliance.
Note that the deadline is the same for engine model years 2000-2003 (2020), and the same for model years 2004-2006 (2021), and the same for model years 2007-2009 (2023).
Also note that no differentiation is made for the 2003 model year that had both the 7.3L as well as the 6.0L engine.
Note further that the deadline is the same for the 2007 6.0L engine, versus the newer 2008 6.4L engine.
And fnally note that the 2010 6.4L engine gets a pass, while not substantially different than the 2008 and 2009 engines that are forced to be retrofitted (with what? The same engine?) in 2023.
Obviously, if you are subject to these regulations, you need to do your own due diligence in determing how to comply. I'm not an expert, I am not liable for your reliance on this information. I posted what I researched online, as well as at what I learned in the CARB training school, in the spirit of sharing tidbits and fostering open helpful discussion with other members who are similarly situated.
Reference: "FINAL REGULATION ORDER" As provided by CARB on December 29, 2011
http://www.arb.ca.gov/msprog/onrdiesel/documents/TBFinalReg.pdf
__________
__________
