CPS Testing Information - Page 8 - Diesel Forum - TheDieselStop.com
'99 & up 7.3L Power Stroke Engine and Drivetrain FAQ Frequently asked questions in the '99 & up 7.3L Power Stroke Engine and Drivetrain forum.
 4Likes
post #106 of 119 (permalink) Old 09-21-2015, 01:57 PM
r7
any news on the quest for the ultimate CPS? Thanks for the great detailed info. I am going to dig around and see what I have. I think I may have an old original black that I installed upon first failure before the recall.
97/98 F-350 XLT, T.Red, Crew, 4x4, PSD, E4OD, SRW, LB, 4.10LS, Warn 4X Boards, K&N, JD Coolant Eye, TorkLift, RideRite, Hayden 679 Tranny cooler, MagnaFine, LubeGard, Fumoto drain, 16x8 EagleAlloy 589's w/ BFG A/T TA LT285/75R16
- NRA Benefactor
r7 is offline
post #107 of 119 (permalink) Old 09-21-2015, 03:24 PM
r7
Alliance AP63400
Has anyone tried or looked at the Alliance AP63400. A local power shop carries it as their standard replacement. Is this comparable to any of the Ford/IH/Motorcraft options, or better?
- NRA Benefactor
r7 is offline
post #108 of 119 (permalink) Old 09-22-2015, 12:43 AM
r7
Looked at an Echlin, BWD and Alliant today
I went around today and looked at:
  • BWD CSS1603 (O'Reillys)
  • Echlin CSS1103 (NAPA)
  • Alliant Power AP63400 (local Diesel performance shop)
The Echlin was the one in the Echlin branded box as per Goog's preferred picture. The BWD and the Echlin appear to be identical. Both are identified on the box as made in Mexico. Both have the larger diameter insert with three dimples and the magnet when tested shows to be centered. They are both brownish-gray in color with a slight color difference between the insert and the top part and both have gold color pins. They are darker in color (and browner) than the second gen OEM gray recall with the purple o-ring model.
The Alliant Power just appears to be an OEM gray.
I took out the one put in by the recall which was the gray one. I am trying to find the black one that I had replaced previously. Perhaps the dealer kept it when performing the recall. Too bad as it was working fine since I had replaced it in kind.
I purchased the Echlin today. Large diameter insert and it centers a pin whereas the gray one I removed holds the pin off center. Hopefully this is the Echlin with the newer Allegro ATS675 sensor.
Now we will see if it generates the RFI issues with the wipers and/or cruise control.
- NRA Benefactor
r7 is offline
post #109 of 119 (permalink) Old 05-19-2017, 04:57 PM
Any opinions on the F4TZ-12K073-C (dark blue Ford CPS which replaces the grey one)
1995 E350 PowerStroke ambo
Ball is offline
post #110 of 119 (permalink) Old 05-20-2017, 10:08 AM
NYB
Ball... The F4TZ-C dark blue CPS did not "replace" the grey CPS. If anything, the opposite would be truer, as the grey CPS was released about a decade later than the dark blue CPS. But in reality, the dark blue CPS is for 94-97 trucks, while the grey CPS (which actually replaced the black CPS) is for 99 up Super Duties.
ArcticDriver likes this.
NYB is offline
post #111 of 119 (permalink) Old 05-20-2017, 11:27 PM
Thanks for the trivia, but I'm more concerned if it's a good part or not.
Ball is offline
post #112 of 119 (permalink) Old 05-21-2017, 04:37 PM
Yes, its a great part for those years. Happy?
02 F250 CC 4x4 7.3 Lariat, 3.73 rears, DPTuner F5, WW2, IH UPs, Airdog+Frx, HPOilX, BanksMonster Exhaust, Centramatics, Gearvendor, Custom rear springs, [BTS!], 130k, Dieselsite 203, Eaton Truetrac. FYI- Blackout/2/3 all me! Can't get back into my original logins.
blackout2 is offline
post #113 of 119 (permalink) Old 05-22-2017, 12:35 AM
Happy?
LOL, I didn't know this forum was for snooty French waiters. I was just looking for advice on a part.
Ball is offline
post #114 of 119 (permalink) Old 05-22-2017, 06:29 AM
ArcticDriver's Avatar
Monsieur Ball,
This site is simply full of Powerstroke owners who like to help out other Powerstroke owners in a respectful and friendly manner.
NYB likes this.
SOLD:
ArcticDriver is offline
post #115 of 119 (permalink) Old 05-22-2017, 06:20 PM
NYB
ArcticDriver has the right idea! As this is an FAQ forum, it is important that we get the FACTS right, so as to not misinform future searchers who have the same frequently asked question. These engines were made when many of the current crop of diesel technicians were still in grade school, and the engines were obsoleted prior to many of the current technician's entry into the trade or training. So that makes it all the more important for similarly situated owners of these vehicles to be able to pass along relevant information in both a factual as well as a friendly manner.
Thanks for the trivia,.
I didn't know this forum was for snooty French waiters..
This isn't very friendly. And the concern for getting the facts straight about successive CPS sensors isn't "trivial". In addition to changing colors of the plastic bodies of the sensor, Ford/International also changed the metallurgy of the contacts, so installing the wrong sensor in the wrong vehicle can potentially lead to accelerated corrosion of the contacts due to dissimilar metal corrosion. The camshaft position sensor signal is sketchy enough as it is, without adding more potential problems that would remain undetected until a fault.
When that fault occurs in the middle of a busy intersection, (or on a four lane highway leading to and from an international airport--- don't ask me how I know) the consequences could potentially be catastrophic. Significant enough for Ford to issue a recall covering hundreds of thousands of vehicles. Recalls are not issued trivially. Manufacturers usually do all they can to skirt by these costly campaigns. So when a recall does happen, it means the issue should at least be seriously considered.
For a 1995 Econoline 7.3L PSD, the dark blue F4TZ-12K073-C is the right choice.
NYB is offline
post #116 of 119 (permalink) Old 05-22-2017, 11:11 PM
Good to know. Thanks
Ball is offline
post #117 of 119 (permalink) Old 05-29-2017, 12:53 AM
Googs's Avatar
I still read your responses NYB , who are ya talking about here? haha
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
post #118 of 119 (permalink) Old 05-31-2017, 10:26 AM
blue99stroker's Avatar
welcome back Dave!!!
The dark blue/purple cps usually works better than the ford grey.
#3 and #8 usually always fail with the grey.
The dark blue/purple has a little bit stronger magnet to pick up the cam gear better.
My truck seemed to idle better with the dark blue/purple.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #119 of 119 (permalink) Old 05-31-2017, 01:18 PM
also using dark blue in my 99 Icut open gray cps and twisted sensor to center super glued it drilled hole in cap hot glued it together installed it truck passed cct scared to get on hyw. like to know measurements of original cps wanted to mill some off to get sensor closer to cam wheel can't figure out how to add pictures
stumpman is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > '99 & up 7.3L Power Stroke Engine and Drivetrain > '99 & up 7.3L Power Stroke Engine and Drivetrain FAQ
