Barder's 360 bearing rebuild,XDP billet,Applied Performance - Page 2 - Diesel Forum - TheDieselStop.com
'99 & up Upgrades and Aftermarket - 7.3L Engine FAQ Frequently asked questions in the Upgrades and Aftermarket - 7.3L Engine forum.
post #16 of 52 (permalink) Old 07-14-2014, 10:47 PM Thread Starter
Now your turbo is ready to install the actuator.
They need to be preloaded with tension or you will have waste gate flutter.
Some do 6 wraps of turn buckle and then pull on it with vise grips to get end onto post.
You can hook up compressed air to the actuator and watch gauge as the gate lever starts to move and adjust accordingly.
Take your time.
Good luck
Nick
Maryland dieselnick is offline
post #17 of 52 (permalink) Old 07-15-2014, 02:21 AM
2000Ford250's Avatar
NICE writeup,
Ill be using it this next week when i put mine together,
THANK YOU
2000 F-250 XLT ,6spd, Short,bed, (when I bought it, 134,000)
6637 DIY Air Filter, EV2 Pyro,Boost Gauge,Muffler-Delete (came that way),Turbo Rebuild with Billet RiffRaff Wheel,(Balanced)
Turbo and Spider, Painted Red,Intercooler-Tubes,Painted,RED,NON-EBPV Pedestal,Painted,RED,EBPV valve delete Mod
TurboMaster WasteGate controller
DRK Blue CPS, "Black" one in the Glovebox
1-9000 longmile trip
now sportin 175,000
24ft alpenlite,sliding hitch, for those days when civilization isnt so civilized
2000Ford250 is offline
post #18 of 52 (permalink) Old 07-15-2014, 04:45 PM Thread Starter
Thanks good luck with it.
post #19 of 52 (permalink) Old 07-16-2014, 12:37 PM
NYB
All that work balancing, and then you go and slather a glob of green paint on one of the blades. Tsk Tsk.
VERY NICE WRITE UP. In 15 years of reading this forum, I've never seen as detailed of a write up on the bearing and CHRA internals as you have so excellently photographed and explained.
NYB is offline
post #20 of 52 (permalink) Old 07-16-2014, 03:25 PM
klhansen's Avatar
My Photos: (180)
Nice work, Nick. Your thread has been nominated to go in the FAQ subforum, so that's where it's going. I'll leave a redirect for about a month, which will still show up here.
), AIS,
regulated return,
klhansen is offline
post #21 of 52 (permalink) Old 07-17-2014, 01:19 PM Thread Starter
Thank you both very much. I am flattered to receive such praise from two members of such a high caliber as the two of you and on the arguably best Powerstroke forum in the world.
Thank you again
Nick
post #22 of 52 (permalink) Old 07-17-2014, 01:26 PM Thread Starter
Oh yeah and NYB the painted witness marks you saw were placed there by Arundel Diesel.
They assemble,torque and balance the assembly. Once the computer says it a go they put witness marks on it so everything ends up in the same spot after you disassemble it and reassemble it in the rebuild process.
Really NYB ? You know I would have blown an eyelash or dust of that.lol.
post #23 of 52 (permalink) Old 07-17-2014, 03:03 PM
NYB
Of course you knew I was teasing you about the greem paint. I think you should have posted that pic in answer to the question about how the balance is restored on reassembly. But perhaps your turbo was baking in your kitchen at that time.
Looks like you've started a trend... "Nick's Crispy Compressor Cookbook"
NYB is offline
post #24 of 52 (permalink) Old 07-20-2014, 04:55 AM
Googs's Avatar
That looks real nice Nick , now you have all that done you might be able to mow the lawns.
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
post #25 of 52 (permalink) Old 08-05-2014, 02:14 AM
Originally Posted by Maryland dieselnick View Post
Now install the compressor wheel to 120 inch pounds.
If you had assembly balanced snug and tighten wheel till the witness marks made by shop on shaft and wheel align.
Next place cover on and torque to 17 ft lbs.
Are you saying torque to 120 inch pounds and then snug further to align witness marks? Also, how do you ensure that the centrifugal force of the turbo under operating conditions won't change the position of the witness marks as it torques itself down further?
AKFLshooter is offline
post #26 of 52 (permalink) Old 08-05-2014, 02:16 AM
blue99stroker's Avatar
just torque it to the correct amount and forget it. it cant loosen itself off off and if it gets a little tighter there isnt anything you can do.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #27 of 52 (permalink) Old 08-05-2014, 03:36 PM
Yeah, I guess the most I'll be able to do is inspect the alignment once it's installed and has been run under load for a bit to see if it moves.
post #28 of 52 (permalink) Old 08-05-2014, 06:10 PM Thread Starter
The shop makes marks after it is torqued and balanced. Get the torque close and continue tightening till the marks line up.
post #29 of 52 (permalink) Old 08-05-2014, 06:16 PM
That's what I needed to know, thanks Nick!
post #30 of 52 (permalink) Old 08-05-2014, 07:28 PM Thread Starter
No problem, you seem ok for an AK guy.
I am an AR guy.
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > '99 & up Upgrades and Aftermarket - 7.3L Engine > '99 & up Upgrades and Aftermarket - 7.3L Engine FAQ
