Navistar / IH Water Pump Upgrade - Page 6 - Diesel Forum - TheDieselStop.com
'99 & up Upgrades and Aftermarket - 7.3L Engine FAQ Frequently asked questions in the Upgrades and Aftermarket - 7.3L Engine forum.
post #76 of 79 (permalink) Old 09-11-2018, 07:53 AM
Does that pump have a built -in filter like the Navistar?
The Grand Pooh-Bah is offline
post #77 of 79 (permalink) Old 09-11-2018, 07:56 AM
Originally Posted by DonWarkentin View Post
For comparison, I will report on my aluminum water pump. This was installed on 5/2/2018. It is AIRTEX AW4114 from RockAuto. It was installed along with Gooch flush, new thermostat, thermostat housing, fan, fan clutch, radiator, and Shell Rotella Ultra ELC. So far, no problems. It is working perfectly.
Does that one have the built-in filter like the Navistar?
2001 F250 CC 4x4 7.3
  • ATS Exhaust
  • Riffraff Intake
  • PHP Hydra Chip
  • 285/75R16 Toyo Open Country R/T
  • Access Bed Cover
  • 05-07 Harley Headlights with Morimoto 55w D2S 5.0 Projectors / 80mm RGB Halos / RGB Demon Eyes / Morimoto Bluetooth Controller / Yellow LED Strip / Switchback LED Turn signal
  • Raptor Style Grill
post #78 of 79 (permalink) Old 09-11-2018, 10:29 AM
No, I'm not using a filter.
DonWarkentin is offline
post #79 of 79 (permalink) Old 08-30-2019, 02:12 PM
Saw this post and got excited, but then I see on the Dieselsite that it won't work with dual alternators?! What the actual hell??
BEASTLY250 is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > '99 & up Upgrades and Aftermarket - 7.3L Engine > '99 & up Upgrades and Aftermarket - 7.3L Engine FAQ
