2008 Steering Pulse on curves - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-15-2014, 10:00 PM Thread Starter
2008 F350, low miles 62K on the clock. I have started having a pulsing in the wheel on long curves. It has gradually gotten worse. Power Steering fluid level is normal. Any thoughts?
PT996S is offline
post #2 of 7 (permalink) Old 12-16-2014, 08:41 AM
No sounds just movement in steering wheel? Jack it up and inspect steering/suspension parts, e.g. ball joints, tie rod ends, wheel bearings.
fatboytx is offline
post #3 of 7 (permalink) Old 12-20-2014, 06:01 PM
Sounds like a tire. Possibly a slipped belt in the tire or low air pressure. That's generally the first sign is a wobble in the wheel more pronounced on curves.
tomlin is offline
post #4 of 7 (permalink) Old 01-07-2015, 03:06 PM
Hi guys, new to the site. I had the same problem. It felt like a dead spot in the steering. Do you notice your brake pedal locking up as well at the same time. The power steering (ATF) fluid became contaminated somehow. It has something to do with the hydroboost system.
Tforman is offline
post #5 of 7 (permalink) Old 03-27-2019, 02:52 PM
Reviving this old thread, as my 08 F350 4x4 has the same problem. Tires pull the wheel back and forth in the middle of long turns at highway speeds, both left and right. New tires did not fix the issue and it does it whether braking or not. Truck has 168,000 miles and I'm sure front suspension/steering components are worn, but steering seems tight otherwise. Wondering if anyone has a specific fix for this issue.
1996 F250 Supercab 4x4 7.3L PS
2004 Excursion 6.0L PS
2005 F650 Flatbed VT365
TDubya is offline
post #6 of 7 (permalink) Old 03-27-2019, 09:46 PM
If you have a LS rear end it can cause problems with turning (usually tight turns(. Did you have the rear axle serviced lately?
DENNY
DENNY is online now
post #7 of 7 (permalink) Old 08-30-2019, 10:44 PM
2x6 Bulldog's Avatar
Front hubs on locked rather than on automatic. This will cause drag when turning.
2008 F450 DRW CC LWB 4x4 Off Road, Lariat, Oxford White, 4.30 LS rear end, Navigation, audiophile stereo, Memory package seats, heated seats, heated mirrors, warmup heat option, power back window, traction control system, backup alarm, rear DVD with wireless headphones.
2x6 Bulldog is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
