High mount brake / cargo light not working - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 09-18-2017, 03:24 PM Thread Starter
Hi all. I'm new to this site. I have a 2008 f250sd. Which has the issues with the cargo light only not working. The. Brake lights work. I checked all fuses and relays and they are all good. Had to replace the light due to being burned out. Switch to an led light
I checked the voltage at the light. The brake light is getting 12 v. However the cargo is reading .002v. Pics below
I do have other issues that I am current working out. The front dome/map light is burned out and seems to work on one side only if the bulb is in the right position. Pic below both side are like this
I know the cargo light should turn on when the door is open. The key phob is used or the know next to the headlights switch is rotated fully up
Is the wiring to the cargo light tied to the dome/ map light?
Charger_ff is offline
post #2 of 9 (permalink) Old 09-19-2017, 06:44 PM Thread Starter
Ok. I followed the violet wire to the sjb. I tested it and got no power from the plug sjb out. I hooked a 10 amp fuse to a wire that ran from the batter n touched the wire and the cargo light came on. Pulled the plug off and tested it from the pin holes and the lights lite up. Tested the pins where the wire connects n has no power. Also the fist 4 in a square where the violet wire is don't have power either. This is in the sjb. So I'm thinking I need a new sjb
post #3 of 9 (permalink) Old 09-25-2017, 10:53 AM
Don't have any of my info with me right now.
The SJB can disable an output if it goes into an over current event, Some times it can be reset and sometimes it can't. Some Code Readers will tell you if it is disabled. I believe it is a "U" code by my old memory.
MPD56 is offline
post #4 of 9 (permalink) Old 09-25-2017, 11:23 PM Thread Starter
How can it be reset? Right now only the brake light work. Not the cargo light
post #5 of 9 (permalink) Old 09-25-2017, 11:27 PM
klhansen's Avatar
My Photos: (180)
That's not surprising, as they're on different circuits.
), AIS,
regulated return,
klhansen is offline
post #6 of 9 (permalink) Old 09-27-2017, 10:34 AM
To start, did you double check fuse F15 in the SJB. This fuse also powers the running board lights.
The Dealer can check for disable codes and reset it. I'm not sure what other code readers can read the code.
- 2013
F350 CC 4X4 Lariat SRW, Black.
Ordered Dec 2012 - Built Jan 11th 2013 - Picked up Jan 31, 2013.
- 2013
Ford Edge
Built Nov 26 2013 - Picked up Dec 06 2012
-2008
F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29.
-1972
First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson).
-First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards.
-1982 - My Sister married a GM Sales Manager (He Retired, "Hello" Ford Super Duty, enough said, LOL).
-2003 - ZRX1200 (Some say "Mid Life", LOL).
-2008 - Jayco 313RKS 5th Wheel.
MPD56 is offline
post #7 of 9 (permalink) Old 09-27-2017, 11:13 PM Thread Starter
Didn?t check that one. But #10 is good. I did take a fuse tester to all fuses n it showed they were all good. Will ch cl it when I get it out of the body shop
post #8 of 9 (permalink) Old 09-28-2018, 04:06 PM
Hunter6146's Avatar
High mount brake light wiring
I hate to bring it by your old thread but do any of you have the wiring schematic for the high mount brake light and possibly one that has the camera mounted in it? Im trying to retrofit my 2015 super duty lariat to have the 17 high mount brake light with the camera
Hunter6146 is offline
post #9 of 9 (permalink) Old 03-25-2019, 08:27 AM
It's not the brake light switch...if the regular brake lights come on when the peddle is pressed. The three lights are all fired off the same switch. Messing with that switch may cause problems for the guy that loans you his switch and for your switch. I was told that switch is a one time install. If you take it out it quits working. - this statement is unverified but may be true.
slide9595 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
