No Power to Trailer Brake Controller?? - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 06-30-2019, 04:35 PM Thread Starter
I have a 2008 F-350 long bed crew cab diesel 6.4. I have the notice on the dash saying "trailer brake module fault" and there is no power to the controller. (verified with my meter). I have power to the fuse 5 in the engine bay and the fuse is good...... I also still have charge power to the 7pin trailer plug so I know the fuse and relay in the cab are working. it also appears to have lost the ground as I can't get continuity to ground from the plug to the battery. Is there a connector between the plug for the back of the controller and the rest of the harness? I have +12 volts on the brake signal when the pedal is pressed so in know some of the wires are connected to the plug..... Help!!! I'm pulling my hair out here!
Lcsodiver is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
