Rear Camera connection location - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 02-24-2019, 04:46 PM Thread Starter
sdharlow's Avatar
Question Rear Camera connection location
2010 F350 Factory rear camera question. Where does the factory wiring connect to the camera at the back? Truck is/was set up from the factory with this option. Finally figured out my rear view mirror does not work because the Sync microphone will not pick up, and the compass on the dash does not register. Have a new "used" mirror on the way. My tailgate handle has the hole for the camera, but the camera is gone. And I do not see any wires going into the tailgate. All the fuses are in place for the rear camera, so someone removed it at some point. Want to get it back in operation with a replacement camera.
Just need to know where to look on the back end for a connection point. I see an oblong hole in the end of the truck bed, and a larger square hole in the bottom of the tailgate, and they are pretty close to each other. I'm assuming this is where wiring would route? Have no idea what to look for under the truck though.
2010 F350 Lariat 4x4 Super Duty aka Blue Beasty
You're never too old to have a Happy Childhood
sdharlow is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 General Questions
Similar Threads
7.3L Bulletins Part 2 DieselDog2 '99 & up 7.3L Power Stroke Engine and Drivetrain 2 02-07-2016 03:51 PM
Add rear camera to 2006 F350 Superduty Stampeder 1999-2007 General Questions 5 08-12-2012 01:57 PM
Wireless Rear View Camera draboo 1999-2007 Upgrades and Aftermarket - General 0 04-04-2012 01:17 PM
pre-wiring for rear view camera? unionhill 2008- 2010 General Questions 2 10-02-2008 11:38 AM
F-450 Differential FLUIDS and TYPE of DIFF?? Open or L/S SKEET298 '99 & up 7.3L Power Stroke Engine and Drivetrain 16 02-12-2006 01:46 AM
