Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   2008- 2010 Ordering Information (https://www.thedieselstop.com/forums/f56/)
-   -   Ford F450 tow truck (https://www.thedieselstop.com/forums/f56/ford-f450-tow-truck-252888/)
wadesautoac 03-21-2010 04:41 AM
Ford F450 tow truck
can i order a tow truck straight from the dealer?
Jonstoy 03-21-2010 12:34 PM
no you would have to order a cab and chassis truck first, or buy one off the lot and then take it to a body upfitter that would install the tow truck body on your rig. However if you find the right dealer they probably will have the means to help get you exactly what you want and need. By that i mean that the dealer probably has certain upfitter companies that they deal with on a regular basis and would then be able to get your truck rigged up.
colotow 03-21-2010 11:17 PM
best thing (speaking as a tow driver and mechanic) would be to go talk to the wrecker manufacturer first, and make sure it's spec'd out properly for towing, upfitter switches, biggest tranny coolers you can get, pto provisions, cab to axle length, and so on.
HARLEY6LF250SDU 03-22-2010 10:56 PM
Give me a call, I can help you with whatever you need.
randy
Ford Fleet/Comm Truck Mngr. 406 544-6891
LSchicago2 03-31-2010 07:58 AM
You can order a tow truck from a towing equipment dealer. They will give you fleet pricing on a chassis. I saved a lot of money by not buying from a car dealer. Where are you located? What kind of truck/ bed do you want?
wadesautoac 04-01-2010 01:58 AM
well i plan to get a f450 to start. i plan to start a towing business. i am in hawaii
LSchicago2 04-01-2010 09:03 AM
Since you are in Hawaii, your choices are really limited. I don't see any towing equipment dealers in Hawaii, so you will probably buy a truck (or bed) in Cali, and have it shipped to you. Since you are starting with a F450, I assume you will be building a wheel lift truck, and probably a self loader. I found this distributor in Anaheim that might help: Tow Trucks, Rollbacks, Flat Bed Car Carriers, For Sale
Good luck!
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
