HLA's are a cylinder with a piston inside and also a return spring. The new HLA's will be springy due to no oil inside but the ones removed are full of oil and will not yield without some force. The HLA has an oil inlet check valve but for it to compress oil has to escape between piston and the HLA bore. This will happen as it should in engine with engine at normal operating temp and oil that is 180+ degrees. Effectively there is no way to hold it in your hand and determine it is bad other than to inspect for wear on the ball end where rocker arm rests.
This is what James was meaning by using vise to see if will compress and oil will escape. You would have to apply pressure, wait, pressure, wait, pressure, wait until the HLA bleeds the oil out and compresses.
Did the rocker arms get inspected for condition of the rollers and tips?
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
