Just finished replacing Lash Adjusters/Rocker Arms - Page 2 - Diesel Forum - TheDieselStop.com
2008- 2010 Gas Engines Discussion of the gas engines available in the 2008- 2010 Super Duty trucks
post #16 of 23 (permalink) Old 02-15-2014, 12:06 AM
chuckster57's Avatar
If your not getting a P03XX code, no need to change them.
Sent from AutoGuide.com App
Train Horns:
PM please not visitor message
chuckster57 is offline
post #17 of 23 (permalink) Old 02-15-2014, 01:21 AM
Chuckster is right. I'd add that the boots can be replaced without the coil.
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline
post #18 of 23 (permalink) Old 02-15-2014, 06:52 AM Thread Starter
cyclone3565's Avatar
Well I figured that if I am going to pull them I might as well install new ones, that way I have a nice history. COP's, 2 out of the eight are Motorcraft (I installed them), the other 6 are some aftermarket stuff. I am not popping any codes at all.
Martin - Fort Worth, Texas
2008 f-250 Lariat
- 5.4 Gasoline - Absolutely Love It
2003 F-250 FX-4
--Sold my last diesel
cyclone3565 is offline
post #19 of 23 (permalink) Old 02-15-2014, 07:51 PM Thread Starter
All 8 plugs came out without any issues, very scary though. 4 of the eight were hand tight only, 2 i needed a bit of ratchet help and 2 were tight. Of the eight plugs, 4 did not have any electrode left. Replaced with brand new SP-515, complete with Anti-seize, torqued to 28 to 30 pounds, replace 5 Coil Packs, now they are all Motorcraft again. Noise is completely gone, quiet as a Church Mouse, absolutely wonderful.
2008 f-250 Lariat
2003 F-250 FX-4
post #20 of 23 (permalink) Old 02-15-2014, 08:27 PM
That's great! Last one I did, 7 of the 8 plugs came apart. Took me about 3-4 hours to change all the plugs.
Train Horns:
post #21 of 23 (permalink) Old 02-15-2014, 08:33 PM Thread Starter
I started at 7:30 and by 8:15 I had them all out and was amazed that the truck ran as well as it has been, judging by the plugs.
2008 f-250 Lariat
2003 F-250 FX-4
post #22 of 23 (permalink) Old 02-16-2014, 07:31 AM Thread Starter
Here are some pictures of of the plugs I removed.
2008 f-250 Lariat
2003 F-250 FX-4
post #23 of 23 (permalink) Old 02-16-2014, 07:37 AM Thread Starter
Here are some more. Notice, how the center electrode is burnt off on quite a few of them. Also, just looking at them you can see which ones were lose. I am absolutely amazed that this problem is not more common. I had to do quite a bit of digging to find this. I am sure there are a lot of people out there that have this noisy engine and have ford make all kinds of repairs. I had taken mine to the dealer here for an oil change (too old for that myself and the dealer is so cheap - $25.00) and the service advisor immediately pointed to the Cam Phazers. What a money maker!!!!! You would not believe the difference this made. Amazing
2008 f-250 Lariat
2003 F-250 FX-4
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 Gas Engines
