Hello from TX - Diesel Forum - TheDieselStop.com
New Member Introductions & Forum Assistance If you are new to the site, please stop in to say "hello" and tell us a bit about yourself. For members having a hard time with a forum feature, this is the place to find answers and ask questions.
post #1 of 9 (permalink) Old 04-02-2019, 09:48 AM Thread Starter
Burly3's Avatar
Hello from TX
New member glad to be on this forum 2008 F350 4wd srw
Burly3 is offline
post #2 of 9 (permalink) Old 04-02-2019, 11:32 PM
Welcome! Looking forward to hearing more about your truck.
DonWarkentin is offline
post #3 of 9 (permalink) Old 04-03-2019, 04:54 AM
Fix
Fix's Avatar
Hello and welcome, all the way from Europe.
Hope Texas is treating you well.
Fix is offline
post #4 of 9 (permalink) Old 04-03-2019, 09:35 PM
Texkenusmc's Avatar
What part of TX I am right on the TX-La. state line.
Texkenusmc is offline
post #5 of 9 (permalink) Old 04-04-2019, 04:14 AM
Hello! Welcome to the forum!
Jimndield is offline
post #6 of 9 (permalink) Old 04-04-2019, 05:57 AM Thread Starter
Burly3's Avatar
Brenham, west of Houston
Burly3 is offline
post #7 of 9 (permalink) Old 04-05-2019, 04:25 PM
Texkenusmc's Avatar
I go out your way about once a month if you ever need your codes ran or need to look at live data let Me know.
post #8 of 9 (permalink) Old 04-25-2019, 03:44 PM
By the way, new guy here as well. Whenever I'm taking a break from this particular interest, I'm usually found at home, watching my ferret play in his ferret nation cage and having fun with the wife and kids. Such a simple and noble life. Cheers, everyone! Have a nice day!
post #9 of 9 (permalink) Old 04-25-2019, 05:47 PM
Welcome
If you put some info about your truck in the signature block below like Don has it helps when you have a question.
DENNY
DENNY is offline
  Diesel Forum - TheDieselStop.com > General Discussion > New Member Introductions & Forum Assistance
