Newbee checking in - Diesel Forum - TheDieselStop.com
New Member Introductions & Forum Assistance If you are new to the site, please stop in to say "hello" and tell us a bit about yourself. For members having a hard time with a forum feature, this is the place to find answers and ask questions.
post #1 of 8 (permalink) Old 09-23-2019, 01:30 PM Thread Starter
Newbee checking in
I purchased by first diesel truck this year to pull our 5th wheel trailer. I have a lot to learn and I'm sure I'll be asking a lot of questions in the near future.
Sent from my XT1254 using Tapatalk
plscott1951 is offline
post #2 of 8 (permalink) Old 09-23-2019, 01:47 PM
Big Horn's Avatar
Welcome. What Model/Year truck did you buy, and what part of the Country are you from?
2002 F350 7.3L / 4R100 - 4WD CC DRW 8í Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #3 of 8 (permalink) Old 09-23-2019, 03:12 PM
Welcome! I hope you really enjoy your truck.
DonWarkentin is offline
post #4 of 8 (permalink) Old 09-23-2019, 03:23 PM Thread Starter
I have a 2019 Chevy 2500HD
post #5 of 8 (permalink) Old 09-24-2019, 12:49 AM
pitstop's Avatar
Welcome aboard and congrats on new truck!
pitstop is offline
post #6 of 8 (permalink) Old 09-24-2019, 11:16 AM
WELCOME
Go to your profile and edit you signature block with all the truck info. See mine below. This information will help when you ask a question so we all know what we are dealing with when we give an answer. Also add your location, you do things different in Texas then Alaska.
DENNY
DENNY is offline
post #7 of 8 (permalink) Old 09-26-2019, 10:45 PM Thread Starter
Originally Posted by DENNY View Post
WELCOME
DENNY
Thank you, I'll definitely do that..
post #8 of 8 (permalink) Old 10-03-2019, 02:08 PM
Welcome to the forum! Cheers!
Jimndield is offline
  Diesel Forum - TheDieselStop.com > General Discussion > New Member Introductions & Forum Assistance
