Drag racing - Diesel Forum - TheDieselStop.com
Off-Road Discussions Off-Road, modifications and racing forum. This is for Off-Road racing only, The Diesel Stop does not promote speeding or racing on the street and does not promote tampering with ANY EPA pollution devices for street driven cars or trucks!
post #1 of 8 (permalink) Old 07-07-2011, 10:19 PM Thread Starter
Drag racing
I'm wanting to go drag racing but am not sure on how to launch the truck. From a dead stop now all I do is spin the tires. So anyone who has raced please let me know how to launch the truck properly.
bigpower77 is offline
post #2 of 8 (permalink) Old 07-07-2011, 10:48 PM
chuckster57's Avatar
Before anybody can really help you, we need to know your current set-up. Go to your "account" and update your signature with the information about your truck including any mods.
In my younger (dumb) days, I knew guys that used sand bags in the bed to hold the back end on the ground.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 8 (permalink) Old 07-07-2011, 11:02 PM Thread Starter
Sorry here are my mods. 2010 f250
H&s mini mas tuner on hot setting
Afe intake
4" down pipe to 5" race exhaust
post #4 of 8 (permalink) Old 07-07-2011, 11:08 PM
Okay we're getting closer..Now go to your account and put all that info in your signature along with the rest of the info...reg cab,long bed, auto trans.....rear end if you know it..
Train Horns:
post #5 of 8 (permalink) Old 07-07-2011, 11:09 PM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
Try 4WD...if you have it? 2WD...air down tires (with weight as stated) or splurge on some slicks?
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #6 of 8 (permalink) Old 07-08-2011, 06:30 PM Thread Starter
Wow ok, I didn't know it was so hard to answer a simple question. I was just seeing what others have done to get down the 1/4 mile. Next time I'll try to be more specific. O and if it helps it's a black truck.
post #7 of 8 (permalink) Old 07-08-2011, 07:38 PM
I wasn't trying to slam you, but it helps a bunch to know what your working with in order to make any informed suggestions. Different strategy for take off if it's an auto vs manual. Sorry if I offended you.
Train Horns:
post #8 of 8 (permalink) Old 07-09-2011, 10:46 PM
Black? Your Screwed. LOL
Seriously though I would power brake to spool up the turbo a bit and launch in 4WD. Depending on if you take off in 2WD, 4WD and the air pressure your time could be a second different.
Removing teh rev limiter adn using lower profile tires will change things up too.
2OOO F-250 4WD Crew Cab, 267,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator, H2O Pump. AIS Severe Duty Filter, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Mesa, Arizona
PRDATR is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Road Discussions
