Making 2wd into 4wd - Diesel Forum - TheDieselStop.com
Off-Road Discussions Off-Road, modifications and racing forum. This is for Off-Road racing only, The Diesel Stop does not promote speeding or racing on the street and does not promote tampering with ANY EPA pollution devices for street driven cars or trucks!
post #1 of 5 (permalink) Old 04-15-2011, 11:10 AM Thread Starter
Making 2wd into 4wd
i have a 99 F250SD 2wd just wondering if its at all possible to swap it into 4wd, what it would cost, what it would take etc etc.
StrokeThis92 is offline
post #2 of 5 (permalink) Old 04-24-2011, 10:18 PM
front axle $500
transfer case $400
probably around $1100 total do it
enzofires is offline
post #3 of 5 (permalink) Old 04-25-2011, 06:18 AM
Mark Kovalsky's Avatar
My Photos: (6)
You will need to change the transmission output shaft, or change the transmission. To change the output shaft EVERYTHING needs to come out of the trans.
Mark
Former
Automatic Transmission Engineer 1988-2007
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #4 of 5 (permalink) Old 01-02-2012, 07:09 PM
easier to buy a 4x4. than to convert
01 f250 4x4 7.3 psd, DEP 4" stainless exhaust w/muffler delete, 5" AFE tip, egt-boost-tuner gauge,K&N air intake,DP-Tuner w/no-start,stock,60T,80E,120Race,140 extreme.
01f250powerstroke73 is offline
post #5 of 5 (permalink) Old 02-10-2012, 11:34 AM
X2
You will have a lot of little things that will suck $, brake lines, fluids, filters, u-joints, drive shafts...etc.... Steering will be an issue, i.e. will a new box be required or just new tie rods. I have had several friends ask the same question. My answer is always sell it and buy a 4x4, will save $ in the long run.
Mike Strickland
Web Master
BigCountryOff-Road.com
2003 F-450 4x4, 6.0 PSD, 4.30 Gears, Western Hauler, 19.5 Wheels/Tires; EGR Delete, ARP studs, HPOP, bypass fuel system, cold air intake, EGT gage(more to come), SCT tuner
RajinCajun is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Road Discussions
