Rear diff lock? - Diesel Forum - TheDieselStop.com
Off-Road Discussions Off-Road, modifications and racing forum. This is for Off-Road racing only, The Diesel Stop does not promote speeding or racing on the street and does not promote tampering with ANY EPA pollution devices for street driven cars or trucks!
post #1 of 4 (permalink) Old 11-23-2011, 05:37 PM Thread Starter
jorelp's Avatar
Send a message via MSN to jorelp
Rear diff lock?
84 F250 6.9 diesel. how do i intentify the axle to buy a diff lock? ive heard people say dana44, dana 50, and dana 60? is there a stamp somewhere? i dont think the axle is original.. its 8 bolt and one side is left hand thread(older im assuming?) these trucks are horrible in 2 wheel drive. one wheel on a little puddle and i have to get out and lock the front hubs.
jorelp is offline
post #2 of 4 (permalink) Old 11-25-2011, 10:33 PM
Greg03PSD's Avatar
This information comes predominantly from the "Differentials" book from Randy Lyman of Randy's Ring & Pinion.
You can probably eliminate the Dana 44 pretty easily as it is a light duty axle that is not suitable for use on a 3/4 ton truck and were never installed as original equipment on anything bigger than a 1/2 ton. Another disqualifier is the 8 bolt axles - you won't find them on a Dana 44.
The Dana 50 is a front axle application only, and modifying it for use in the rear would be very expensive, complicated, and pointless (if even possible).
So out of the 3 you listed, the Dana 60 is the most likely - it was also the axle that Ford originally installed in the F-250 until 1985. I have also read that left hand thread lug nuts were used on the driver's side during that time.
There are 2 other Dana axles that might look similar to the 60 - the Dana 61 & Dana 70. The 61 was only used on 2 wheel drive F-250/F-350 & E-250/E-350 applications from the mid '70's to mid '80's. The Dana 70 was used on dually applications almost exclusively (used by Ford, Dodge, GM, International, and Jeep)
Usually the easiest way to identify an axle is by the shape and bolt count of the rear cover since any other markings on the axle are either not permanent in nature or covered by rust. There may be a tag on one of the bolts on the differential cover, but those tags usually only identify gear ratio and possibly the presence of limited slip. In the book I have, the Dana 60/61/70 cover is the same, so the only way to tell the difference between them is by gear ratio and ring gear diameter.
If you can post a picture of the cover, I'll compare it to pictures in my book, or you can find pictures of the axle covers somewhere in the vastness of the internet.
2003 F-250 4x4, 7.3L PowerStroke
6" Skyjacker Z-link lift, 35" MT Baja ATZ tires
18" Wheels
Warn 16.5Ti winch w/ hidden mount
Front & Rear ARB Air Lockers
Dynatrac Free-Spin Front Hub Conversion
Edge Juice Programmer
Fabtech Ladder Bars
AutoEnginuity w/ Ford Enhanced package - New Hampshire seacoast - Just bring beer!
Greg03PSD is offline
post #3 of 4 (permalink) Old 11-26-2011, 04:49 PM Thread Starter
jorelp's Avatar
thats loads of info!! thanks man. well, ill be pressure washing the underside with in the next couple weeks and letting it dry before i give it fresh undercoating. once its all cleaned up i'll snap a few pics.
jorelp is offline
post #4 of 4 (permalink) Old 12-26-2013, 11:00 AM
Post
a bit late but fod future needs here is a site showing most used diffs covers and axle id charts.
https://www.google.com/search?q=diff...bgUxl7CWTiM%3A
http://www.drivetrainpartslasvegas.c...ory_s/1869.htm
larry
kg6tgu
2006 F250 4X4, 6.0 w/ auto, quad door cab, short bed.
for now just a stocker set up for pulling a fifth wheel, and moto transport.
N 38*09*900
W 120*49*900
packnrat is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Road Discussions
