sled pulling gear - Diesel Forum - TheDieselStop.com
Off-Road Discussions Off-Road, modifications and racing forum. This is for Off-Road racing only, The Diesel Stop does not promote speeding or racing on the street and does not promote tampering with ANY EPA pollution devices for street driven cars or trucks!
post #1 of 45 (permalink) Old 10-05-2006, 10:36 PM Thread Starter
sled pulling gear
would it be better (easier on tranny) to pull in 2nd and lock the tc with my switch or to use 1st(high/low?) thanks guys!
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
jasonlambert is offline
post #2 of 45 (permalink) Old 10-05-2006, 10:55 PM
CSIPSD's Avatar
My Photos: (52)
Re: sled pulling gear
I used 4low and shifted it from first to second... But I didnt win...LOL
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #3 of 45 (permalink) Old 10-05-2006, 11:01 PM Thread Starter
it wont break shifting?lol is that better than taking off in 2nd?
1969 mach 1 mustang
post #4 of 45 (permalink) Old 10-05-2006, 11:20 PM
CSIPSD's Avatar
My Photos: (52)
no, it will not break... I dont think you would hurt anything other then the 2nd cluches...
Joe
CSIPSD is offline
post #5 of 45 (permalink) Old 10-06-2006, 06:07 AM Thread Starter
should i lock the tc or leave it?
1969 mach 1 mustang
post #6 of 45 (permalink) Old 10-06-2006, 06:59 AM
bbunting's Avatar
if you only use 2nd, you won't pull far-4lo drive, od off-lock the converter in 2nd
My truck BEST ET: 12.89 MPH: 109.24
bbunting is offline
post #7 of 45 (permalink) Old 10-06-2006, 08:42 AM
rdvit94's Avatar
I pull in 2nd gear 4 low and usually place pretty good (3rd-5th place). I started off in 1st gear once by accident and then shifted to 2nd, but that didn't work out good at all, the engine bogged down and I lost my momentum. I haven't tried bbuntings idea yet, but I think I am doing pretty good in 2nd gear. What ever you do don't run in 1st gear, you definitely don't need that low of gear and you won't get enough speed.
2001 F-350 XLT, CC, LWB, 4x4, Auto, Off-Road, DP-Tuner (stock-40-80-120), SP Diesel Air Intake, MBRP 4" Exhaust, Banks BHA, TAG, Dieselsite BRV, AIH Mod, 203 Stat, Sonnax/Tri Kit, Tank Mods, Redhead Steering Gear, DB Electric Starter, Di Pricol Gauges in A-Pillar, 3.5" Custom Lift, 315/75/16 BFG ATs, Delta Toolbox
rdvit94 is offline
post #8 of 45 (permalink) Old 10-06-2006, 08:46 AM
bbunting's Avatar
Having pulled a sled once or twice, I can tell you that whomever pulls it the fastest pulls the farthest (on a properly set up sled). MPH is everything-you want it to get into 3rd if the track is long enough.
bbunting is offline
post #9 of 45 (permalink) Old 10-06-2006, 10:27 AM
imelmo's Avatar
I want to ride in your truck if you're pulling in TX to see how it's done if that's ok.
2002 F-250 Lariat 4x4 crew-cab short-bed automatic, lots of stuff from DI Performance (Diesel Innovations)713/984-9441, Terminator hpop, ATS trans, and some good help from Chris Pitre at Pitre Automotive of Lafayette, LA 337/945-8049 (and a few other great sponsors) pm me for any details; Best time on 37's = 13.09 @ 102mph, #2 only;12.18 @ 111.71mph on Da Juice
Current Project: '86 Toyota regular cab, full tube chassis, fully built 7.3 Diesel Innovations Powerstroke engine and Terminator hpos
imelmo is offline
post #10 of 45 (permalink) Old 10-06-2006, 11:06 AM
rdvit94's Avatar
bbunting,
I agree with what your saying, speed is definitely a key factor, but in 3rd gear will a stock truck or slightly modded truck have enough power to keep the sled moving? Obviously your truck has more than enough power, but if you can remember when your truck was just slightly modded, did you have enough power? I would think the truck might start down shifting which could hurt your momentuem [img]/ubbthreads/images/graemlins/shrug.gif[/img]
rdvit94 is offline
post #11 of 45 (permalink) Old 10-06-2006, 11:31 AM
Turn the chip to 120, get it moving, put foot to floor and let it go to 3rd. If you don't lay it all out you will be pissed konwing you could do better.
2002 F350 Crew Cab, homade Tymar intake, muffler delete, DP Tuner stock-40-80-120 (smokes like a freight train), Autometer Pyro, Tranny, and Boost gauge.
1952 Chevy Truck
383 stroker backed up by a 700R4
1938 Ford Truck
Someday to be a crew cab with a 514 ford stroker and c6 tranny
kstoner is offline
post #12 of 45 (permalink) Old 10-06-2006, 11:59 AM
My Photos: (5)
bbunting,
I don't think a slightly modded truck will pull 3rd gear all that well. Last year my truck was just standard bolt ons (AFE stgII, DP chip, Suncoast, exhaust) for most of the year. I had a pulling tune from Jody that was setup to shift 1st and 2nd and not go into 3rd. I had 35's which probably hurt me because when the pan came up it pulled it down real quick, but they also helped me get a decent MPH. A 33" tall tire in 2nd gear low at 3200 RPM should get you around 20 MPH. That's my 2 cents. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
D2HP is offline
post #13 of 45 (permalink) Old 10-06-2006, 02:27 PM
Tom S's Avatar
My Photos: (20)
I pulled in drive one time with my mild mods and as soon as the truck went into drive it totally bogged down and then downshifted. It did a ton better just pulling in second. I am sure there are lots of variables that effect this with power and gearing being biggies.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood,
PMF RSK V and B code springs
Tom S is offline
post #14 of 45 (permalink) Old 10-06-2006, 02:41 PM
Last time I pulled I put it in second and it hit the rev limiter very fast and I ended up pushing it into third but forgot to turn overdrive off. It ran through third then hit od and bogged. But I can keep the rpms right at about 3000 with the converter unlocked in third. second gear just isn't tall enough even with the 35,s and 373 gears with a locked converter it hit the rev limiter really fast.
2000 F250 powerstroke diesel 4x4, 4 door, Lariat,
big injectors, 76mm turbo
Black 2006 F250 Crew cab short bed lariat 2wd stock 120 miles as of 4/17/07
thedieselkid is offline
post #15 of 45 (permalink) Old 10-06-2006, 02:43 PM
Has anybody ever done a boosted launch on the sled. I mean like giving the truck as much throttle as the brakes can hold back and then just letting off the brakes and matting it.
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Road Discussions
