sled pulling gear - Page 3 - Diesel Forum - TheDieselStop.com
Off-Road Discussions Off-Road, modifications and racing forum. This is for Off-Road racing only, The Diesel Stop does not promote speeding or racing on the street and does not promote tampering with ANY EPA pollution devices for street driven cars or trucks!
post #31 of 45 (permalink) Old 10-08-2006, 01:09 PM
bbunting's Avatar
Re: sled pulling gear
here is an example of what I am talking about
video
Programmed shift points, in drive, based on wheel speed.
My truck BEST ET: 12.89 MPH: 109.24
bbunting is offline
post #32 of 45 (permalink) Old 10-08-2006, 01:55 PM
That was a nice pull, now after seeing that I think I want a sled pulling program.
thedieselkid is offline
post #33 of 45 (permalink) Old 10-08-2006, 03:55 PM
Wouldn't third gear in 4 low be about the same as 1st high. You just have the extra 2 gears down low if you start bogging and you have some help getting the rpms up when getting the sled going.
It's pretty close, I just thought the big horsepower guys used HIGH range for wheel speed.
I don't want to think about the amount of power going through the LOW range gears of the TC with the transmission in the lower gears.
I'd think with proper axle gearing, you could use HIGH range and take the load off the TC gears which would be the weak link.
444turbodiesel is offline
post #34 of 45 (permalink) Old 10-08-2006, 04:06 PM
Not sure how well that would work. I do know that the TC is very strong. I would think that the rest of the drive line would break first.
post #35 of 45 (permalink) Old 10-08-2006, 04:38 PM
The fewer gear reduction sets you run the power through, the more power ends up at the wheels. Which is the reason most dragsters have gone to direct drive (no transmission) with the only gear reduction in the axle. Of course this would only be practical in a dedicated pulling truck.
Just thinking outloud...
I haven't been inside a 271 to see the gear set, but if guys like bbunting are running in LOW range, it must be pretty robust. Running in direct (HIGH range) would be more efficient though if you got the axle ratio right.
post #36 of 45 (permalink) Old 10-08-2006, 08:13 PM
In a 6sp there is 4mph difference between 4th low 2nd high and the same between 2nd high and 5th low. Thats counting as 1(L)23456.
mech2161 is offline
post #37 of 45 (permalink) Old 10-08-2006, 08:22 PM
So what are you running in? (HIGH or LOW)
post #38 of 45 (permalink) Old 10-09-2006, 06:27 AM
I pull low on a tite track and high on a loose track.
mech2161 is offline
post #39 of 45 (permalink) Old 10-09-2006, 08:25 PM
The problem pulling in drive with just a slighty modded truck is that if you start to bounce and have to back out of throttle, the truck downshifts into 2nd. Pulling first gear high range is about the same as pulling in drive buts it pretty easy to get under the turbo as the sled catches up. Another thing to watch is your competition. If your at a pull with a lot of big power trucks that are stopping 275-300, with a lightly modded truck you dont have enough track to let the truck get into drive and take advantage of the wheel speed before the sled hits and shifts the truck back into second anyways. Now if your in a true "street" class where its all trucks with chips, tuners, etc and stock or very mild turbo ugrades and the sled operator as the sled set accodingly, yes drive is the way to go. I my self almost always pull 2nd gear, convertor locked.
whitestroke00 is offline
post #40 of 45 (permalink) Old 10-09-2006, 09:14 PM Thread Starter
whitestroke, do you take off in 1st or second? about when do you lock the tc?
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
jasonlambert is offline
post #41 of 45 (permalink) Old 10-10-2006, 07:32 AM
I saw some fool in a 6.0 pullin' in 4-hi 1st.
Didn't do all that bad.
That fool took it for 305' in high range
1999.5 F350 CC LB AT 4x4 Dually, Burgundy/Black, MBRP 4" Stainless exhaust, IssPro gauges, Jody Tipton 4 pos chip, BB Turbo, Big ol' hybrids, DI stainless reg return, Not Big oil but let's call it "MEDIUM" oil for now 140,000 on stock tranny b4 she puked, BTS in its place
416 HP/860 TQ
1969 SS396 Chevelle <--- fave toy
pipewhiner is offline
post #42 of 45 (permalink) Old 10-10-2006, 07:36 AM
bbunting's Avatar
post the vids....
bbunting is offline
post #43 of 45 (permalink) Old 10-10-2006, 10:12 AM
They are posted Brian. We have even talked about them in chat!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
416 HP/860 TQ
post #44 of 45 (permalink) Old 10-10-2006, 04:36 PM
I take off in second and lock the convertor as soon is i get my foot to the floor and the rpms hit redline.
post #45 of 45 (permalink) Old 07-26-2012, 09:14 AM
Paul H's Avatar
My Photos: (10)
Just wondering what 4:56 gears and lockers will do
was told once to leave it in drive, and loc the converter and let it pull till it runs out of power
Paul H
OWNER
2004 Ford F350 6.0L Dualie 273.000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty EGR delete running ELC all stock
1996 Ford F350 7.3L Dualie 343,000 Tony Wildman custom burn,5 inch stacks, good ole girl(in Avatar)
1995 Ford F250 7.3L Regular Cab 255,000 miles Sled Puller
Paul H is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Road Discussions
