New SDD3250 dual friction dual disc - Diesel Forum - TheDieselStop.com
South Bend Clutch
post #1 of 1 (permalink) Old 03-09-2012, 12:22 PM Thread Starter
• We at South Bend Clutch heard the call for the organic dual disc clutch but wanted to offer the best in both durability and drive-ability. How do we achieve that? In our 50 years of experience we knew that running an all organic dual disc would have it’s problems. The intermediate (center) plate is approximately ½” thick whereas the pressure plate and flywheel castings are three times that. Running two friction surfaces on one thin casting will increase the temperature to that casting. Organic burn point is approximately 550 degrees whereas ceramic can reach 1100 degrees. The immediate engagement points when the clutch is released for takeoff are the outside points of a dual disc clutch, pressure plate and flywheel. Being that there is only one friction surface running to these two points, and the fact that the pressure plate and flywheel castings are much thicker than the center plate, the temperatures cannot reach that of the center plate. This is why organic will work to the pressure plate and flywheel and not to the center plate.
• We at South Bend Clutch feel we have reached a milestone in the clutch industry and hope that you will enjoy our hard work at being the industry leader in research and development of clutches for the diesel market.
sbclutch is offline
  Diesel Forum - TheDieselStop.com > Vendors > South Bend Clutch
