Southbend Clutch Just In - Diesel Forum - TheDieselStop.com
South Bend Clutch
post #1 of 3 (permalink) Old 12-01-2009, 10:41 PM Thread Starter
TonkaThunder's Avatar
My Photos: (6)
Ok, so my clutch is in. But.................. I've got questions!!!!! When the tranny is in neutral clutch engaged I hear an extra rattle from right below me, I push in the clutch pedal and the noise is instantly gone. And one other noise, any RPM below 1,250 under slight acceleration or decel it almost sounds like grinding gears but everything is already engaged. So my question is are abnormal sounds normal, until I put a few more miles on the clutch? Theres only about 50 miles on the clutch right now
03 F-350 DRW Lariat 7.3,4x4 6-Speed, 4.10Gears , 4 inch ProComp lift, BFG AT LT315/75R16, 3 in. spacer between duals.
GT38R 1.0 Housing
Banks Monster Exhaust, w/Turbo Elbow, AFE Stage 2 Cold Air Kit, South Bend Stg 2 Clutch & Cyro'ed Flywheel
Full Force Stage 1 Singles & TS 6-Position
Auto Meter Boost and Pyro Gauges
8,200lbs---Cat Scale---Thats me and and 38 Gallons of Diesel
3 Road Race Fox Body Mustangs( I have a disease! :])
34 Ft Kaufman Solid Deck 2-Car Hauler
TonkaThunder is offline
post #2 of 3 (permalink) Old 06-21-2010, 06:24 PM
depending on what stage the clutch is yes. If you have one both springs and rubber isolators on the disc or solid hub as i do then there will be a rattle in neutral until slight pedal pressure and when in gear at low low rpm 900-1100. not gonna get much better with time though.
95 f-350 cc 4x4 5sp 4.10 35x12.50-16 292,000mi so far,haisley machine twin disc street puller, k&n intake aem dry flow filter,4"magnafow exh. fpr to 73psi, Ts 6 position stacked with a steroid t module, air lift rear bags, banks intercooler,flex-a-lite electric fans. best improvement HMR twin disc clutch great for pulling anything.
birk is offline
post #3 of 3 (permalink) Old 06-21-2010, 06:42 PM Thread Starter
My Photos: (6)
Its the Stage 2 clutch, and yes there is I beleive 4 isolaters and 2 springs. So I knew it would be alittle noisier
GT38R 1.0 Housing
  Diesel Forum - TheDieselStop.com > Vendors > South Bend Clutch
