Looking for member 99SD - Diesel Forum - TheDieselStop.com
Members' News Discussion and news about members of TDS!
post #1 of 4 (permalink) Old 07-29-2019, 02:05 PM Thread Starter
Hi I am trying to find a member 99SD Member #40608. He has some info on a Allison conversion I could really use. I am going from a Allison 545 to a Allison MT 643 Behind a T444e. He has a List of all the part and a Drawing form Allisn AS04-317. It would be a big help if I could get this. Thank You
J Presnell is offline
post #2 of 4 (permalink) Old 07-29-2019, 03:56 PM
klhansen's Avatar
My Photos: (180)
99SD hasn't posted here since 2008. You might try sending him a Private Message, but after all that time, don't hold your breath. I changed your thread title which may help it to be seen.
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old 07-30-2019, 11:41 AM Thread Starter
1998 T444e trans change
Thanks Klhansen I am ok with computers, but not great your help is appreciated thank you very much. Would you have a Email address I could start with? If not I understand thank you.
post #4 of 4 (permalink) Old 07-31-2019, 01:37 AM
https://www.thedieselstop.com/archiv...o=&fpart=1.htm
Link to parts. I couldn't find the drawing though.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > General Discussion > Members' News
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
panhead george
