Hey guys I'm new here and I just got my truck back from the shop and I had new turbo, lift pump, edge monitor and a 6 position chip installed and I'm making 7 boost in race mode started looking at things and realized hose clamps were loose and the red line on turbo was off of it tightend and put the wier back on and still not making boost any ideas and suggestions would be great thanks
Two suggestions, Check the up pipes for leaks and never go back to that shop.
DENNY
Will do and we don't plan to except to go and complain and see what he did will all the fuel took it up their with a full tank and got it back with less then a quarter tank this shop is diesel up in Newburg IN
I don't have any leaks or restrictions anywear. Is their any pressure suppose to be on that red line going to the back of the turbo because if their is suppose to be theirs not.
How are you driving it to see the boost pressure? If you are just driving normally take it out onto the freeway and mash the go peddle or take it where there are some hills and then do the same thing and see what it reads.
