Some friends and I just got through installing a Pro Comp lift on a buddy's 01 F250, and my brother wanted me to ask you guys what it would take to mount the 01 springs on his 97 F250 4x4. Also he wondered how much lift it would give the front(if any) and if the back would need to be blocked up. Also he just replaced the shocks with OEM replacements and he wanted to know if they would be long enough.
The easiest way to do it would be to install a reverse shackle kit in the front. If you don't want to build your own (GTS powerstroke has prints on his website) Off Road Unlimited and Sky Manufacturing both make them. I used the Sky kit and was very satisfied. The only thing I had to do with theirs was make custom sway bar links. If you do the reverse shackle kit, it will probably lift he front about 3-5 inches depending on how sagged your front end is now. My truck is an F350 and I had add a leaves with almost new springs. It went up 3 in. From my experience you would need longer shocks. I am using ones off of a 94-97 F450 Superduty. Another option alot of guys seem to be running is the Bilsteins that are made for a lifted 99- superduty pickup. If you don't want to gain any extra height, you still have a couple options. Some guys have used the brackets from the superduty pickups and adapted them to our style frame. I was also looking at some brackets I have off of a 1978 F250 4x4( not a highboy) and they would fit quite nicely.
