Around 55K mi. I started to have varying levels of braking issues. Typically the truck would pull hard left when exiting interstate highway on off-ramp 65-70mph. This symptom came and went with out any specific regularity or common environmental similarity. Took the truck for aligment and the shop would not touch the truck as all the alignment parameters were dead-on perfect. Tire wear was acceptable, and I continued to drive for another 15K mi. with symptoms coming and going irregularly. At 70K mi. I had new rotors, calipers, pads installed and a month later the symptoms, althogh less severe, reoccured but the "pulling" was now both to the left (80% of the time) and right. Took the truck back to the shop (3x's)and they put in shim kits and changed pads with little or no affect. When the symptom first occurred it became increasing stronger to the point where hard or emergency braking would pull the wheel out of your hand and the truck would "dive" hard left. Now at 95K mi. the symptoms are very infrequent and weaker. Anyone have any expierence/or advice?
