Changed the GPR and now truck will turn over but wont start. I started having a problem with electrical issues. Truck would run but die on its own after 10 mins of idle but now to the point it won't start. Turn the key and relays under dash click.
With key off, I have 13.5 volts on the big constant post of the gpr and 0 volts on the other 3 posts like normal. With the key on I have 13.5 volts on the big constant post and 0 volts on the other big post, 7 volts on the little front post and 7 volts on the back little post which is the ground. Could I have a bad pcm now? These issues are throwing me for a loop
