Anybody had this problem and got an ideal what it might be. Thanks for any information.
Mine does that also...I just thought it was designed that way :lol:
Griz
The switch is on the latch. pull apart the door latch and replace. It is a screw in. If you pull your door panel and look in you can see it. You have to remove the outer handle also.
my moms dodge truck is the same way, it does shut off after a few minutes so it might be normal stupid i think.
