Hi, this is going to be a long read so I can give as much info as I can remember. Tried starting my 7.3 diesel and when I released the key the starter kept cranking until batteries were depleted. Pulled batteries, checked and charged. Installed batteries. As soon as I hooked up POS post on driverside battery, starter started cranking. Disconnected and starter stopped. Reconnected and nothing. Pulled starter relay and turned key no crank. Plugged relay in turned key and starter cranked. Let go of key and kept cranking. Turned key to off and kept cranking. Pulled starter relay, kept cranking. Jumped out and disconnected POS on driverside battery. Cranking stopped. Pulled down fuse panel to check for GEM moisture. GEM is not there. GEM is located below radio on firewall. Visual check after 15 min of hose on windshield. No leaks. While Driver side POS TERMINAL off I noticed Passenger side battery was venting off steam. Disconnected and it stopped venting. Pulled starter and primary alternator and had tested. Starter tested OK. Alternator tested bad NO CHARGE. Replaced alternator and reinstalled starter. Replaced the ignition slide switch. Hooked up both batteries after recharged and load tested OK. Turned key and observed normal gauge sweep, normal dash light, fuel pump pumping gauge reads 60psi, air pump pumping, normal growl, turned to start and starter cranked. Released key and starter kept cranking. Pulled starter relay and kept cranking. Had to pull POS off driver side to stop starter. I noticed that the starter cranked faster when key position was in off position just for a moment. HELP it's so cold here my upper body parts could cut glass and I am working outside because truck is too high for garage.
