In the middle of doing a 4wd swap and I think i'm missing a piece.
On my mono-tube stock axle, there are pads for the leaf springs and brackets for the sway bar on both sides of the axle. On my 4wd axle, the pad/bracket is present on the passenger side, but not the drivers side. There's nothing for the the u-bolts to tighten to nor anywhere to bolt the sway bar.
I cannot figure out what this part looks like or a part number for it. Does anyone have or can take a photo of their 450/550 4wd leaf spring front so I can see how it attaches? Or if you know what this part number is, that would be awesome too.
Thanks in advance.
Track Bar goes from left frame rail to right front of axle. Is that what Ur seeing? A pix would help.
No, I have the track bar installed and bolted up. This is the part that bolts the axle to the leaf spring on the drivers side. I think I need this piece.
I know it's from another forum, but it's the only Pic I can find.
In this picture, the bracket under the front pumpkin that the u-bolts are going through, is that YC3Z-5A316-AA? The part I pictured above?
