I've got an 03 F-250 6.0 with 36,000 miles on it. I really haven't had any serious problems with it other than the early rolling idle problem a lot of people had. Took it out last week for it's first hard pull of the season with our 5th wheel. Had two 4 hour runs and one 8 hour run. The same thing happened each time. About 1 hour into the trip the pedal would go dead. I could step on the gas and nothing would happen. The tach would not budge and it sounded like the throttle hadn't changed position. Anywhere from 5 to 30 seconds later the engine would start to make power and it would pull like normal. Once this started it would keep happening until I pulled over shut the truck off and restarted it. It would work fine then, but the problem would recur later. I could always correct this by shutting off the truck and restarting it.
The second problem (which I don't know if it's related to the first) is about 3 hours into the trip on the highway the truck would start bucking and missing very violently. Excessive smoke would be pouring out the tail pipe then the truck would backfire through the air box a couple of times then you could hear the turbo spool up and it would belch a huge amount of black smoke out the tail pipe and run fine for a little bit and then start all over again. It would buck so hard I fully expected the bottom end to drop through the oil pan at any time. I tried my original pull over and shut the truck off procedure, but that had no effect on this problem. The truck runs fine when I'm not pulling. I've taken it to the dealer, and they told me they've got another truck in with the same symptoms, but so far I'm getting the impression that they're still scratching their heads a bit over this one. Any ideas?
