I am installing an 03 6.0 into my 04 6.0 f250- so far I have noticed the ICP is above the hpop instead of the oil rail- can I just run the wires back to the earlier sensor or do I have to change the heads? what other changes do i have to make? thanks in advance
Yes you can run the wires back to reach also check where the ebp sensor is located on each you may have to reroute those wires also. Other than that you should be good to go IIRC.
Did you use the wire harness for your 04 on your 03 you are installing? Same with ficm?
How did it turn out ?
