First and foremost I would like to thank every body for responding to my question you all were VERY helpful!!! Thanks!!! /ubbthreads/images/graemlins/biggrin.gif Well here goes, Ggg6 said that I should check the turbine wheel for damage melting so I thought about it and said I will do that, and fix the exhaust leak before I take it to ford. So after A big battle the leak is fixed (new header bolts) so I removed the pipe off of the turbo and peered in with a very bright light, its like looking into a black hole!!! I found that the turbine wheel looked like as if a mouse got in there and chewed the fins right off of the wheel!!!!!!!!!!!!!!! DOH!!!!, So let me back up as I was taking the inlet piping off there is a coil thingy looks like a heater? with a porcelain part in the middle of it well that was down in the intakes where the screens are, and one of the screens is broke also!!! so It looks like the heater broke and the screen broke and all of this went thought the motor and found it way to the turbo and broke that!!!!! /ubbthreads/images/graemlins/mad.gif also the part that broke in the intake was replaced and it looks like its new (no oil-n-stuff on it) so I would say that the people that sold this rollback knew about it and that makes me mad!!! So off to ebay I go to look for parts to fix my problems!! DOH!! Hey also how do the up tubes seal to the manifold on the back of the turbo they have those rings is that like a squish deal? /ubbthreads/images/graemlins/shrug.gif
Again thanks to all!!! Any body have a turbine wheel for sale? Any body have any directions for takeing the turbo apart? Tips tricks? Thanks!!! Doug
