you have an injector sticking and when then engine cools a little at idle its not burning all of the fuel . when you start driving again the temps go up and the fuel is burned so it not as visible unless you are at an idle . the egr has an effect on this problem , but will not stop it . will help clear it up . you can try pulling it out and cleaning it off . if there is alot of carbon on it it sticks and will be stuck in the middle of open and closed .
Had This
I had the exact same problem on mine. Took back under warranty and had a bad EGR.
Mine acted very similar when my EGR cooler started leaking. So much water in the engine it wouldn't hardly rev, and smoked like a steam engine.
Justin
