My rear shock mounts are bent like these?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
    0
1 - 12 of 12 Posts
I have not had any luck finding a picture of the rear axle shock mounts that are bent like this. They are pretty much the same between the two.
I have a right rear spring sag of about 3/4" from the left so I will be replacing the spring packs with 4400# units because this truck has had a Lance camper on it all its life. The shocks are new as are the sway bar end links.
Anyone have shock mounts like this?
Are you saying the shock mounts are bent from the load and weight/side shift of the camper?
I am asking if anyone has seen similar axle shock mount that is bent sideways as in the picture.
Ok , gotcha- fabricated at an angle. I’ll check mine- recently did shocks but don’t remember
Since they're symmetrical, I'd say they were fabricated like that. Looks like the offset from the axle mounting point is toward the wheel on each side. Not sure why they would have fabbed them like that, but there must have been some reason.
BTW, your photo links are kind of strange. You can post photos directly from your computer, and they should show up without having to right-click and select "view image". I see that yours are a dropbox link. If you delete them, they'll go away here, but photos uploaded here from your computer will be permanent (well --- relatively.)
Discussion Starter #6
Thanks! I would appreciate it a lot! I noticed it during a shock and sway bar endlink change. I have a right rear sag that I think is a weak spring issue.
My ‘02 F350 lower shock mount has no offset, it is 90* to the axle tube. Looks like we need some input from owners of other ‘04 F350’s
Sent a PM
The picture links are broken but my 2006 and 2015 duallies have the brackets curved a little so they look bent. My 2005 F450 has different brackets but they are offset a little too.
The picture links are broken ....
They're just weird. You can right click on the link and select "view image", and it should show them to you. (Windows anyway).
I think it is a Firefox browser issue. I opened in another browser and the broken link icons weren't there and pics opened. Those photos are exactly what the 06 and the 15 have on their Dana 80 housings.
They don't even show up when I right click and select "show picture" in MS Edge, like they do for me in Firefox.
1 - 12 of 12 Posts
