Hello all,
I recently bought a 2004 F350 King Ranch, drove it for a few days with no problems and went to start it up one day and it was deader than a door nail. I jumped it and noticed the drivers side seat warmer (which doesn't heat the seats) was left on once it was running. I drove it around for 10 minutes or so and parked it, went to restart it and it cranked for a second and died.
After that I couldn't get it to start via jumping it, so I took the batteries to AutoZone where one was found good and the other was bad (pass. side). I got one new battery as they were only purchased in 12/21. And installed, all good to go.
I was at work a couple days later and my wife tells me that it is dead again. I get home from work the next morning and try to jump it, with no luck. So we went out and get a battery charger and after about 10 minutes on the charger it fires up and runs just fine. I check the battery % indicator on the charger and it shows 95%. It does look like there was the drivers side dome light left on after starting it up. I let it run for approx. 5 minutes and shut it off. It does the same thing; turns over for just a second and drains to just clicking and then just clicks but wont turn over after that.
Also, the battery charger does have an alternator % gauge and it shows as "Lo". Soooo... I figure ok well ill pull the alternator to take it and see if it is bad. Take it and have it tested, shows its good.
So... now what?
First you have to replace both batteries. A dead battery will kill a good battery and replacing one will cause the old one to destroy the new one. You have to have 2 new batteries. Next the alternator may test good but I have found a bad battery will eat a good alternator. I keep a close eyes on my batteries. At the first sign of corrosion I replace them both even if the other one looks good.
Also, make sure all the battery connections and ground points are solid and free of corrosion.
Reactions: Stroking it
