Truck is an 04 F250 with a Torqshift auto. Approximately 100k miles on it. When the ambient air temp is anything below 60 degrees, and the truck has been sitting overnight, the tranmission will not upshift until you back out of the throttle, it will then upshift and do the same thing through all the gears. Once it has cycled through the gears (or warmed up) it will shift normally for the rest of the day.
If the truck is left idling to warm up for a long enough period of time, it will shift normally the first time out.
When it won't upshift until the throttle is released, it will hold that gear all the way to redline (with or without a load on it) After the truck has been run, or when the ambient air temp is warm, it acts normally. This isn't a big problem to me, but I'm curious if there is a solution to it?
I had the same issue. Had 2 fuel injectors bad and the Fuel Injection Computer (FICM) was bad. These trucks are based so heavily on computers, it affected how the transmission shifted. Once mine was warm transmission shifted fine. Hope this helps, at least a place to start.
Well the FICM holds 48-49V at WOT, so that should be ok. I have run a buzz test on the truck and it has no issues there. Truck runs very smooth on startup, hot or cold, and does not seem to have a miss under any conditions. Injector 4 was recently replaced, but the shifting issue was there both before, and after its replacement.
Any codes? Also are you running the stock air box?
