i have a 2004 f250 this all start with it taking 7-10 sec to fire up when it was warm then it went from that to not starting at all and now it wants to start again just fine when its cold im not sure where to start looking any ideas?
Early or late 04? If so, does it seem to do this when you park it making a right hand turn? If so, it could be the wiring harness.
probly got a high pressure oil leak somewhere in the system.
im not sure if its early or late model i will check, i avnt noticed anything with the turning and it affecting the starting but which wiring harness? cause i also have a problem with it not turning over with the key i just wired in a push button switch for now until i could find the problem. how would i look for a igh presure oil leak?
