Greetings. Doing a brake job on my 05 F250 4wd torqueshift and need caliper bolt torque specs for front and rear please.
Could also use the tork specs on the lug nuts irrc its 165 ft.lbs.?
Any additional suggestions greatly appreciated.
TIA
2005 F-Super Duty 250-550 Workshop Manual
SECTION 206-03: Front Disc Brake
<font class="small">Code:</font><hr /><pre>
Torque Specifications
Description Nm lb-ft
Brake caliper bolts (F250, F350) 76 56
Brake caliper flow bolt 48 35
Brake caliper anchor plate bolts (F250, F350) 225 166
Wheel hub extender nuts 176 130
Brake disc shield screws 11 8
</pre><hr />
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
SECTION 206-04: Rear Disc Brake
Brake caliper bolts —
F-250, F-350 single rear wheel 35 26
Brake caliper flow bolt 35 26
Brake caliper support bolts 137 101
Disc-to-hub bolts 121 89
Brake caliper anchor plate bolts —
F-250, F-350 single rear wheel 275 203
</pre><hr />
SECTION 204-04: Wheels and Tires
Spare tire carrier bolts 20 15
8-Lug M14 wheel bolts — F250/350 224 165
</pre><hr />
Thanks for the info. Much appreciated. /ubbthreads/images/graemlins/smokin.gif
Sorry for reviving such an old thread, but I'm assuming the "anchor plate bolts" (166 ft lbs) would be the ones holding the caliper itself onto the spindle correct? And the "caliper bolts" are the slide pins?
Correct.
