1 - 8 of 8 Posts
I have a 2005 f350 6.0 psd
I started it after sitting for a day and I got a p2285 code, injector control pressure sensor circuit low. Icp reading on my livewire is reading 870 psi. You can press the throttle pedal wide open and you won't get anything. I went ahead and replaced the pigtail to the sensor and I got nothing. I'm clueless on what to do next. Any help is appreciated thank you
What was IPR showing?
Could be the sensor itself that can cause a circuit code as well.
Couldn't monitor the IPR but I ordered a new icp sensor hopefully that fixes it. This truck has been having problems left and right
Just put a new sensor on and still nothing. Has a new sensor and connector. What would be the next thing to look for? Truck starts fine just no throttle.
I'd get a scanner on it and see what IPR Voltage and FICM and see whats going on. That should be able to point you in a good direction if you've already replaced the ICP sensor and harness.
Everything looks good....i'd trace the wiring further back on the ICP sensor and see if there is anything out of whack. A Circuit code generally means sensor or wiring. It may be further in the harness.
1 - 8 of 8 Posts
