I would guess that it is coming from the freeze plug that is behind the starter. Remove the 3 bolts that hold the starter on and you will see the freeze plug.05 Leaking Antifreeze from Starter bolt and from front of Trans.
What’s the problem and what’s the fix? The truck has 117,8000 miles on it and has never been back to the dealer.
Be sure that is is not leaking on top of the engine and running down.Out of curiosity check the hose on egr cooler for signs of leakage05 Leaking Antifreeze from Starter bolt and from front of Trans.
