I have a 06 F350. I have an afe stage 1 intake/air filter, have done an egr delete and have a edge platinum chip. i have been experiencing a gradual decrease in boost pressure. under full load now i am only reaching around 20psi boost. i only put the chip in about 1 month ago. the independant mechanic i use believes it to be the exciter ring as he said he can force it past the 20psi. he says the ring can get notched out and cause it to stick.
the truck has 117,000kms on it and i have premium care so he advised me to try the dealer and see if they would warranty it as the chip should have no bearing on the turbo.
The dealer tech says he pulled chip and got 26psi boost. What is the actual boost under load supposed to be? This still seems low. He says is because of chip of coarse. Also says may have head gaskets gone and is adding to problem. I told them that the independant press tested it and vacuum tested it after the delete and there response was they had there best tech on it.
Another problem is after about -15C the cab won't heat up. they say due to low coolant level but there is still coolant in the degas bottle. when i brought it home checked the level and it was a little low (in bottom 1/4)but in his diagnosis shouldn't he have topped it up? After the first try on the egr delete the independant had to redo it as it had leaked so it is possible that it may be leaking again. Regardless some info would be great as it feels like i'm getting screwed as the dealer charged me $500 to do basically nothing!
