Hi guys, I would really appreciate some help with the issue I came across today.
A little background:
My father has a 2007 F350 Super Duty Lariat with the 6.0 diesel engine. As he no longer drives, I have been driving it for a bit on weekends for him. We do keep a trickle charger on one battery.
The issue I had today:
I needed to move his snow plow, so I mounted it, connected everything while the truck was running. No issues starting up today.
I could not get power to his plow joystick control (power led would not light up) so I rechecked the outside plow plugs, put some dielectric grease on the connectors, but no luck. While the truck was still running, I started checking some fuses that I thought might pertain to the joystick connector (driver's side under steering wheel) but did not see any blown.
Gave up on mounting the plow, ended up just dragging it with a chain with the truck, and parked the truck.
About 6 hours later, I cannot get the truck to crank.
-When turning the key to start, I do not hear the starter click, I do hear some relays in the fuse box click.
-The battery light is on when the ignition is turned on. Hooked up our snap-on battery charger for about 20 minutes, did not help. Usually if the battery was dead after a few minutes it would crank slowly, this time it just flat out would not crank.
-Tried moving gear shifter to neutral, past park, no change.
-Tried using the yellow and blue wire under the hood on passenger side on the battery terminal to try and jump the starter, I get a spark but no crank.
-While I was checking the fuses, I noticed a red wire that went into the fuse box, but did not connect to anything. Not sure what it is for.
I will be going back to troubleshoot some more tomorrow, I was really hoping that someone could point me in the right direction. I need to get the truck started again since it's not in a good place for storage.
Thank you!
Ben
My guess would be the starter has gone bad being that it won't kick over with the wire under the hood but has power there.
x2 either bad batteries out of nowhere (has happened to me) or the starter just crapped out.
Thank you so much guys. I replaced the starter today and it started right up. Much appreciated!
:usaflag2:
