I have 3 vehicles, each have Homelink. It seems only 1 can be programmed for a door opener at a time. If it's working, and I program the other car Homelink, the first car Homelink no longer works. Is this as designed or am I missing something?
Of all the above articles, this is the one that works.Resolved... I had the same issue with my Toyota 4Ruuner and Toyota Tundra. Only 1 can be programmed and the other loses it. I have a Genie garage door (with rolling code) and what finally worked is when i reset the garage door opener by pressing and holding the learn button for 10 seconds. Then programmed the regular remote control that comes with the garage door. And then reprogramming both cars as i did before. This time though both kept the code.
Did you program both vehicles in the 30. Seconds after clicking learning on opener?Resolved... I had the same issue with my Toyota 4Ruuner and Toyota Tundra. Only 1 can be programmed and the other loses it. I have a Genie garage door (with rolling code) and what finally worked is when i reset the garage door opener by pressing and holding the learn button for 10 seconds. Then programmed the regular remote control that comes with the garage door. And then reprogramming both cars as i did before. This time though both kept the code.
I had the same exact problem... You need to reset the actual garage motor itself... they only store so many codes and after it ‘fills up’ it will only keep the last one entered... that is your problem here. To fix, simply press and hold down the ‘learn’ button until the light stops blinkin which means you’ve cleared out all the codes stored.,, now you can go about normal pairing of your handheld and vehicles home link buttons as expected.I have 3 vehicles, each have Homelink. It seems only 1 can be programmed for a door opener at a time. If it's working, and I program the other car Homelink, the first car Homelink no longer works. Is this as designed or am I missing something?
Thank you! In 2021 this is still useful information. I had an issue trying to add my new car to our Homelink and could not figure out why once I program one, I would lose programming with the other car and Genie remote. So for those that need more detailed instructions, please complete the following:Resolved... I had the same issue with my Toyota 4Ruuner and Toyota Tundra. Only 1 can be programmed and the other loses it. I have a Genie garage door (with rolling code) and what finally worked is when i reset the garage door opener by pressing and holding the learn button for 10 seconds. Then programmed the regular remote control that comes with the garage door. And then reprogramming both cars as i did before. This time though both kept the code.
Thanks raynnnn!! I was soooo frustrated until I found your tip. Shame on Genie for not being clear about this! Now I have two cars plus one remote working properly. As it should!Resolved... I had the same issue with my Toyota 4Ruuner and Toyota Tundra. Only 1 can be programmed and the other loses it. I have a Genie garage door (with rolling code) and what finally worked is when i reset the garage door opener by pressing and holding the learn button for 10 seconds. Then programmed the regular remote control that comes with the garage door. And then reprogramming both cars as i did before. This time though both kept the code.
Thank you for this. Worked immediately after following your steps. Only had to tweak the mini cooper protocol.Thank you! In 2021 this is still useful information. I had an issue trying to add my new car to our Homelink and could not figure out why once I program one, I would lose programming with the other car and Genie remote. So for those that need more detailed instructions, please complete the following:
1. You do need to reset the Genie itself by holding the "Learn" button for 10 seconds.
2. Once you do this, you have to reprogram the remote by pushing the learn button once and hitting the button on the remote you want to program 3 times.
3. Now ensure that you have reset your Homelink on your car, Car 1 by zeroing it out by holding both left and right car Homelink buttons simultaneously until it blinks rapidly.
4. After that, you need to go back to Car 1 and hold the remote to the Homelink button you intend to program until the light flashes rapidly.
5. Now go back to the garage Genie and push the learn button once and you have 30 seconds to go back to the car and push the Homelink button you just programmed 3 times holding 2 seconds at a time. One of the 3 times should move the garage door. Once it does, it is programmed. If you push 3 times and it did not move, repeat the steps from zeroing your Homelink button in Car 1. It will eventually work but you have to be patient.
6. After, Car 1 is programmed you can move to Car 2 and repeat all steps from zeroing the Homelink button in that car, Car 2.
7. Once programmed, check that Car 1 and the Genie remote still work individually.
8. If all 3 work individually, you are done!
